h22a
Old Dec 4, 2006 | 11:45 AM
nelsond's Avatar
Default h22a
vtec works for 10 mins then stops.
motor is filled with oil
no ecu codes thrown
changed vtec pressure switch
and vtec solenoid brand new today
my car hits vtec 1 time
then stops and will not work again till after i turn the car off or restart.
no oil leaks
never seen this before
Old Dec 4, 2006 | 11:46 AM
dek1mfk's Avatar
Default Re: h22a (nelsond)
sounds like you might have a faulty ecu....check the ecu and also check your vtec wiring to make sure there arent any loose, or stripped wires
Old Dec 4, 2006 | 11:59 AM
nelsond's Avatar
Default Re: h22a (dek1mfk)
done that there are no lose wires and i have 3 ecu,s and they all work
Old Dec 4, 2006 | 12:05 PM
mgags7's Avatar
sounds to me like there could be oil pressure problems...
Old Dec 4, 2006 | 12:09 PM
nelsond's Avatar
Default Re: (bb4ever)
so what should i do change the oil pump
Old Dec 4, 2006 | 12:12 PM
mgags7's Avatar
I hope that isn't necessary....do you have a helms manual?
Old Dec 4, 2006 | 12:17 PM
nelsond's Avatar
naw gonna get one
Old Dec 4, 2006 | 12:22 PM
mgags7's Avatar
ok, deliii.com should help you on that
check the vtec problems flowchart, there are methods of diagnosing if you have enough oil pressure....that requires an oil pressure guage though...
94wip
12
Jun 20, 2024 07:23 PM
jordan_rael_420
Sep 11, 2008 08:36 PM
eat_sleep_ej1
12
Dec 1, 2007 04:43 AM
nelsond
Dec 13, 2006 10:33 AM
H22T94
Jul 25, 2004 12:50 AM
