LSD & Final Drive Conversion
Old Nov 29, 2006 | 08:22 AM
NH578's Avatar
Default LSD & Final Drive Conversion
I searched but couldn't find any relevant info...
My question is:
Can i install the SiR spec LSD & 4.266 Final Drive into my H22A4 transmission
(Final Drive 4.062) & what are the implications/other parts involved?
Thanks
Old Nov 29, 2006 | 08:25 AM
nonvteclude's Avatar
Default Re: LSD & Final Drive Conversion (Spatial Bleu)
there was a thread in here with a guy that did that final drive. let me see if i can find it
Old Nov 29, 2006 | 08:31 AM
Default Re: LSD & Final Drive Conversion (nonvteclude)
ok here are a couple there not the same but they have lsd with quite different final drive.
https://honda-tech.com/zerothread?id=1377063
https://honda-tech.com/zerothread?id=1385682
also if you search final drive there was some others too
Old Nov 29, 2006 | 08:37 AM
NH578's Avatar
Thanks man! That Turbo Search Engine of yours is da bomb!
I got all the JDM SiR part numbers & just needed to know wether it'll be easiest to change the necessities or the entire box...
Lemme start reading...
Old Nov 29, 2006 | 01:33 PM
E-Money's Avatar
thats a crazy final drive
Old Nov 29, 2006 | 03:07 PM
117's Avatar
117
Are you sure about that FD ratio? What is the transmission code?
As for changing the diff and the final drive ratio, you'll have to do a few things. New diff bearings, set the diff preload, swap the final drive gear rings, disassemble the entire countershaft, install all gears and synchro sets on new countershaft. Fortunately, you don't have to set the end play like you do on the mainshaft.
Old Nov 29, 2006 | 03:37 PM
94Vtecluder's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spatial Bleu &raquo;</TD></TR><TR><TD CLASS="quote">1994 EG8 B18B, B16A Head, Tranny & Pistons, B16B Cams, BC Gears, AEM Pulleys, 4-1 Header & 2.5' Zorst
188whp & 15.1 over 1/4mile in 2380pound body 6000ft above sea level</TD></TR></TABLE>
Damn son, gotta work on that!
Old Nov 29, 2006 | 11:14 PM
NH578's Avatar
Default Re: LSD & Final Drive Conversion (94Vtecluder)
Thanks for your informative comment 94Vtecluder, big up homie!
siopau
14
May 18, 2011 07:46 PM
vader87
Sep 22, 2009 07:00 AM
Jdc5
20
Dec 24, 2008 09:21 AM
lsbrasil
Feb 20, 2008 10:10 AM
shipsaeki
Mar 20, 2003 05:48 PM
