Ignition Timming HELP ??
Old Nov 24, 2006 | 08:22 PM
lukej's Avatar
Default Ignition Timming HELP ??
92 Prelude DOHC 2.3 Non V-Tech
What is the best way to check the timming
Had the timmg belt break,, bent valves,, now it's back togather.. all fixed
HELP THANKS.
Old Nov 24, 2006 | 08:48 PM
Hawkze_2.3's Avatar
Default Re: Ignition Timming HELP ?? (lukej)
Ignition timing you use a timing gun on the flywheel through the special hole in the tranny. You also have to jump the ECU so it doesn't correct for your changes (if you need to change it).
Cam/crank timing use the cam gears plus either the flywheel marks or the mark on the crank pulley.
Old Nov 25, 2006 | 07:18 AM
lukej's Avatar
Default Re: Ignition Timming HELP ?? (Hawkze_2.3)
OK thanks
Mikeyjarey
Aug 14, 2009 08:57 AM
b18c1civic95
Jan 1, 2007 06:25 PM
dizzyroc88
Apr 7, 2006 07:23 AM
bgod
Jul 23, 2001 06:37 AM
