wheel alignment........
Old Dec 2, 2006 | 07:11 PM
jnuanz382's Avatar
Default wheel alignment........
i need help on my alingment.........cause i lowered my car with tien ss and my camber is soo bad......what measurement should i set my alingment.........
Old Dec 2, 2006 | 07:51 PM
InvaderTrax's Avatar
I don't think you full understand what an alignment is. When a shop aligns your car, they adjust toe, caster, and camber (all of these terms can be Googled). The problem is that Honda's don't have adjustable camber, so you need to buy a camber kit. Once installed, take it to a shop and they'll adjust it to where it's correct. There is no "universal setting" that we can tell you to put your camber in spec. For a camber kit, I recommend Ingals. What ever you do, don't cheap out and get a $40 eBay or OBX kit. A camber kit is a very important part of your suspension, and an inferior part can be extremely unsafe
Old Dec 2, 2006 | 08:18 PM
LudaChris's Avatar
Default Re: (InvaderTrax)
Just get the front only. On the rear, buy 8 washers from Home Depot and install it in rear control arm, two washers per bolt, there is two bolts for each arm. Do one bolt at a time so you won't have to struggle putting it back, just loosen the bolts enough to where you can slide the washers in. That should take care of your rear camber. >$3.00
Old Dec 2, 2006 | 08:29 PM
mgags7's Avatar
WTF are you talking about?
Our rear control arms bolt in parallel to the wheel, putting washers in there wouldn't do anything if you could even fit them....you would have to trim the bushing/sleeve in the end of the arm to get them in there....
OP: just have your tow adjusted, the camber doesn't matter. I have the same springs, if you zero out the tow your tires will wear fine
Old Dec 2, 2006 | 08:36 PM
LudaChris's Avatar
Default Re: (bb4ever)
True, my bad bro! That application is for CRX/Civics/Integ. That's for sure.
Old Dec 3, 2006 | 01:39 PM
dreed2300's Avatar
Default Re: wheel alignment........ (jnuanz382)
If you buy the camber kit the shop will align it to the factory specs. I was an alignment tech for 5 years at sears. The machine has all the info the tech needs to adjust them properly so just buy the kit take it and the car to the shop and let them do the rest.
Old Dec 3, 2006 | 05:44 PM
Fa1's Avatar
Fa1
Do Honda dealerships adjust your camber also? I was informed that they only adjust caster and toe angle.
Old Dec 3, 2006 | 06:36 PM
Default Re: (Fa1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fa1 &raquo;</TD></TR><TR><TD CLASS="quote">Do Honda dealerships adjust your camber also? I was informed that they only adjust caster and toe angle.</TD></TR></TABLE>
Normally they only adjust caster and toe because you can't adjust camber on factory Honda suspension. If you have a camber kit and your dealer has an alignment rack, they can do it
Old Dec 10, 2006 | 06:01 PM
jnuanz382's Avatar
so if i lower my can i CAN JUST ZERO OUT MY TOE then my tire wear will be FINNE???? please reply ???????????
Old Dec 10, 2006 | 07:57 PM
Depends on how low, but if you get your toe to normal, your tire wear will be slower, but still to the inside of your tires because you camber will be off. The best way to think of it is if you're going lower than 1.5" you def need a camber kit
turbo-crx
Suspension & Brakes
Dec 31, 2008 06:37 AM
Ran4it2
May 19, 2008 02:37 PM
BJA86
11
Sep 2, 2007 01:00 PM
phuster
May 10, 2005 09:19 AM
d8168055
Nov 29, 2002 08:41 AM
