idle scree adjust
Old Dec 4, 2006 | 05:48 AM
dek1mfk's Avatar
Default idle scree adjust
does anybody know how to perfectly adjust the idle screw on an h22a1 motor....i close it completely by doing a couple turns clockwise....to open it, i have to make counter-clockwise turns...how many full counter-clockwise turns should i make to open it?
Old Dec 4, 2006 | 06:58 AM
GtechPro's Avatar
Default Re: idle scree adjust (dek1mfk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dek1mfk &raquo;</TD></TR><TR><TD CLASS="quote">does anybody know how to perfectly adjust the idle screw on an h22a1 motor....i close it completely by doing a couple turns clockwise....to open it, i have to make counter-clockwise turns...how many full counter-clockwise turns should i make to open it?</TD></TR></TABLE>
No one can tell you how many turns to make. It depends on what RPM YOU want your engine to idle at.
Get your car warmed up to normal operating temperature.
Turn the screw little by little while checking the RPM.
Set to desired RPM at idle.
Old Dec 4, 2006 | 09:56 AM
dek1mfk's Avatar
Default Re: idle scree adjust (GtechPro)
the thing is that if i let my car idle at 900RPM, the car bogs, it needs to be like at 1500RPM or so....i think my ECU is bad....im running a p14 on my h22
Old Dec 4, 2006 | 11:58 AM
GtechPro's Avatar
In that case, adjusting this screw will not solve your problem.
Fix the issue, then adjust idle.
Old Dec 4, 2006 | 12:03 PM
integra15's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GtechPro &raquo;</TD></TR><TR><TD CLASS="quote">
Dont you have to unplug that one sensor prior to adjusting?
Old Dec 4, 2006 | 05:42 PM
hondabigblock's Avatar
If your running a p14 on a H22 that is your problem. You need a p13
Old Dec 4, 2006 | 08:05 PM
k_lude's Avatar
Default Re: idle scree adjust (hondabigblock)
it can be the p14 or just that ur motors jacked
Paprika
May 8, 2007 03:18 PM
drowzysleeper
May 18, 2005 01:40 PM
jerbear!
May 9, 2005 11:00 AM
Tony92lude
Mar 1, 2004 06:38 AM
