starting
Old Nov 28, 2006 | 04:51 PM
Joe...'s Avatar
Default starting
my 5th gen is not turning over/cranking
i did the following
-checked the battery
-fuses.
i have this problem many times i still havent a clue as to what will solve this.
my only guess or thought would be the main relay.....which i dont know where it is
anyone know?
Old Nov 28, 2006 | 05:06 PM
prelude1897's Avatar
Default Re: starting (Joe...)
sounds like you need a new starter
Old Nov 28, 2006 | 09:16 PM
Joe...'s Avatar
Default Re: starting (prelude1897)
any other explaintion before i spend money on a starter....
Old Nov 28, 2006 | 10:14 PM
ludatic98's Avatar
if yours is a five speed then it may be the switch on the clutch pedal. it may need to adjusted or replaced. if it is not enguaged all the way the starter will not even turn over. if you feel like you have to mash the clutch through the floor sometimes to get it to start then this prolly your problem.
good luck.
detailzdelivere
Dec 20, 2009 05:09 AM
bywaters
16
Jan 14, 2009 05:04 PM
fullboostin
Jan 4, 2008 03:49 PM
slammedtegls
Sep 24, 2004 07:05 AM
itrSteez
Dec 4, 2002 06:05 PM
