code 21
Old Nov 24, 2006 | 03:14 PM
gotslicks's Avatar
Default code 21
swapped a h22 into a non vtec luda.
just got a ecu chipped for the car and i got no vtec and code 21.
checked solonoid with 12v and it works.
followed wire to ecu pin a4 and there is continuity all the way.
any suggestions will help.
Old Nov 25, 2006 | 09:12 PM
brucesi's Avatar
Default Re: code 21 (gotslicks)
do you have a oil pressure sensor it should be under the soilnode it goes to the ecu it call VTM you need to have that so the vtec to work
Old Nov 26, 2006 | 03:44 AM
Duane_in_Japan's Avatar
Default Re: code 21 (brucesi)
VTEC issues all over the search archives my friend, not just here in the lude section either, homework time, low oil, dirty VTEC ports and lots of troubleshooting ideas with just a simple volt meter.
asubennett
Apr 14, 2006 03:57 PM
ezza
Mar 16, 2006 01:28 PM
MugeNinja
Dec 29, 2005 09:50 AM
gots_a_sol
Aug 4, 2004 05:32 PM
BigBlockCRX
Jul 29, 2003 06:14 AM
