Compression Test Results
Old Dec 16, 2006 | 02:07 PM
lude98SH's Avatar
Default Compression Test Results
I took a compression test on my friends lude with 130k on it. The results seem almost too good to be true.
225/221/212/220
The car has been maintained well but that seems a bit high for a motor with milage over 100k. What do you guys think ?
The the motor internally is stock.
Modified by lude98SH at 3:18 PM 12/16/2006
Old Dec 16, 2006 | 02:36 PM
hamadiscool's Avatar
Default Re: Compression Test Results (lude98SH)
A high mileage engine builds up stuff inside like sludge and if the motor is in good shape (no leaking etc) then the compression is usually quite good cause the sludge ups the compression. Atleast thats why I think it is.
Old Dec 16, 2006 | 02:39 PM
lude98SH's Avatar
Default Re: Compression Test Results (hamadiscool)
Yea thats wut i was thinking. But after seafoam and engine flush and stuff i figured we would have weakend the seals alittle and cleaned up some of that sludge.
Old Dec 16, 2006 | 04:22 PM
93h22a1vtec's Avatar
all depends on the compression tester, altitude, exc
Old Dec 16, 2006 | 11:31 PM
lude98SH's Avatar
Default Re: Compression Test Results (93h22a1vtec)
It was a cheapy compression tester but I figured it should be around the right number. Also im right outside of philly so our altitude is not high at all.
Old Dec 16, 2006 | 11:54 PM
iam7head's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lude98SH &raquo;</TD></TR><TR><TD CLASS="quote">It was a cheapy compression tester but I figured it should be around the right number. Also im right outside of philly so our altitude is not high at all. </TD></TR></TABLE>
how many cranks and how many times did you pull?
was the battery on charge?
Old Dec 17, 2006 | 02:48 AM
Mr.Lude's Avatar
My 94' Prelude VTEC has 169,000 miles on it. When I did my compression test with a Craftsman compression tester gauge I got 210/208/205/209.
I can't believe it myself lol...I must have some carbon build up in there but I'm really not sure how I got such high numbers for such an old motor. Unless the engine was swapped out with another USDM one which I doubt.
Old Dec 17, 2006 | 06:35 AM
lude98SH's Avatar
Default Re: Compression Test Results (iam7head)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iam7head &raquo;</TD></TR><TR><TD CLASS="quote">
was the battery on charge? </TD></TR></TABLE>
8 cranks and the battery was fully charged
Old Dec 17, 2006 | 06:21 PM
all testers read differently, as long as they are within 5 of eachother dont worry about anything.
Old Dec 17, 2006 | 08:30 PM
lude98SH's Avatar
Well i thought the general rule of thumb was 10% and that 8 points which is less than 5% so i guess its ok.
Old Dec 17, 2006 | 08:34 PM
Mykizism's Avatar
numbers on the compression test gauge isnt really what matters, bc gauges will vary from gauge to gauge.. along with altitude/location.. what you want to look for is comparision numbers across the board.. they are all very similar to each other.. so your good to go!
Old Dec 18, 2006 | 05:35 AM
ludecz's Avatar
When I bought mine a year ago with 150000 miles the compression was around 175 -185 on H22 A1. And the car still made 165 whp at that time!
Old Dec 18, 2006 | 08:16 AM
mgags7's Avatar
8 cranks is a bit much too....4 should be enough from now on
the numbers look good though
Old Dec 18, 2006 | 04:39 PM
fast_honda's Avatar
Default Re: (bb4ever)
I did one with my cheapy and it was 210/210/210/210. The one in auto shop at my college read 230/230/230/230. Yes I'm just bragging. But yeas 4 cranks and remember to pull the ECU fuses to disengage the fuel pump.
88 civic
Apr 5, 2009 03:21 PM
self_made
Jun 19, 2005 12:36 PM
snowblind7x
Apr 13, 2005 08:12 PM
sdinteg
Feb 1, 2005 07:52 PM
builtprelude
Jan 22, 2004 10:49 PM
