reverse issues
Old Jan 27, 2007 | 02:14 PM
goonslude's Avatar
Default reverse issues
I have a 99 prelude with an aem cold air ,aem power steering pully and a neuspeed short throw . Recently i lost reverse. The shifter gose to the reverse spot and the lights come on but it does not go in to reverse. i tried taking the short throw out to see if maybe that was the problem but no luck. then i looked over all the linkages and they were all working correctly. has anyone had the same problem . is it a fluke with the 5 speed tranny or is it something easier
Old Jan 27, 2007 | 02:47 PM
1GPlusSH's Avatar
Default Re: reverse issues (goonslude)
Get someone to help you. One of you get in the car. One of you get under the hood. Whoever is under the hood should shift the transmission my hand. When you figure out how to put it in reverse, see what happens. If it does, I'd see what's up with the shifter and shift linkage. If it doesn't, then I'd say you have a tranny issue.
Old Jan 27, 2007 | 02:52 PM
94Vtecluder's Avatar
Your search for reverse returned 93 results.
Try doing a search. There have been TONS of threads covering this and similar issues. You might find the answer there. Make sure you click the archived box.
goonslude's Avatar
i have done the that and as soon as i start to let the clutch out it starts to grind and shortly after the reverse went second gear is now grinding and i had a few guys look at it while i was working at the honda dealer this is kinda off topic but have you heard of tsx hids for the 5th gen
90datech
Transmission & Drivetrain
22
Dec 15, 2012 06:40 PM
Dr Blood
May 10, 2006 03:42 PM
G0crxG0
40
Apr 24, 2006 07:14 AM
ugot8up
Nov 18, 2004 12:46 AM
AzntstyleZ
Jan 12, 2004 09:37 AM
