clevite or acl??
Old Jan 25, 2007 | 06:40 PM
DrivinVtec's Avatar
Default clevite or acl??
Im not sure which would be better. shooting for 400whp on my h22a4.(01) either cleveite or ACL? what ever one u recommand, could u give me a part number please. thank you.
Old Jan 25, 2007 | 10:18 PM
alphajesse's Avatar
Default Re: clevite or acl?? (DrivinVtec)
OEM.
Old Jan 26, 2007 | 05:10 AM
Speedra500's Avatar
Default Re: clevite or acl?? (alphajesse)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alphajesse &raquo;</TD></TR><TR><TD CLASS="quote">OEM.</TD></TR></TABLE>
+1, thats what I run in all mine, you can order from http://www.hondaautomotiveparts.com
Old Jan 26, 2007 | 07:38 AM
Mykizism's Avatar
both acl and oem bearings are very good, use one or the other, never used clevite dont have much to say on them..
the most important part in bearings is installation.. checking, rechecking, double checking the clearances is the up most important!!!
Old Jan 26, 2007 | 08:02 AM
DrivinVtec's Avatar
okay. thanks for the info.
Old Jan 26, 2007 | 09:16 PM
alphajesse's Avatar
Default Re: (Mykizism)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mykizism &raquo;</TD></TR><TR><TD CLASS="quote">both acl and oem bearings are very good, use one or the other, never used clevite dont have much to say on them..
the most important part in bearings is installation.. checking, rechecking, double checking the clearances is the up most important!!!</TD></TR></TABLE>
You don't really have the ability to get the clearances exactly where you want them with anything other than the OEM bearings.
Old Jan 26, 2007 | 11:04 PM
Mykizism's Avatar
Default Re: (alphajesse)
You don't really have the ability to get the clearances exactly where you want them with anything other than the OEM bearings.</TD></TR></TABLE>
you are right, it all depends on the builder too, you some may prefer to run a looser clearnace, then others.. it all depends on preference and the viscosity of the oil that will be used, and use of the motor
but if you are using ACL and you come with in the spec that you happy with then by all means you can run them. they are not bad bearings, but if a person wants an exact , like dead on exact clearance. then by all means get oem bearings..
ive used acl in all the motors ive built, and i got the clearances that i am happy with, so far all motors are still running!
ive even seen acl bearings taken out of a motor with NO oil pressure, they sure looked damn good for a bearing on a motor running with no oil pressure
Old Jan 27, 2007 | 08:55 AM
LudeyKrus's Avatar
IIRC, both Clevite's and ACL's are trimetal's just like the OEM bearings.
I've seen them both ran in motors and they both worked well. I'd go with whichever was cheaper.
Old Jan 27, 2007 | 09:00 AM
92hondalude's Avatar
Default Re: (LudeyKrus)
Thats what i run everytime i build a engine
baam
22
Apr 24, 2006 06:28 AM
92integraVTECgsr
11
Mar 24, 2006 10:52 AM
914doorls
Jun 8, 2005 03:49 PM
92LudeSI
Aug 26, 2004 04:36 PM
b16a1sirhb
Oct 25, 2003 04:58 PM
