hooking vtec to a switch
Old Apr 6, 2008 | 04:24 PM
strtricer1987's Avatar
Default hooking vtec to a switch
i have a prelude 92 si with a h22a1 swap turbo and it does not have plugs for vtec how do i get vtec hooked up?
Old Apr 6, 2008 | 06:01 PM
v4lu3s's Avatar
RTFM
without the plugs on the vtec solenoid and vtec pressure switch i suspect you are up **** creek.
perhaps start by replacing the missing/broken parts?
Old Apr 6, 2008 | 06:04 PM
manbearpig's Avatar
Default Re: (v4lu3s)
read up on the faq man... what plugs are you talking about?
Old Apr 6, 2008 | 06:41 PM
switched_in_your_eye's Avatar
Dude you just need a vtec buttom mounted in your car and hook it up to your vetech harness.
Old Apr 6, 2008 | 10:19 PM
no1knows908's Avatar
Default Re: (switched_in_your_eye)
You will definitely need the ECU pins so you can wire it to the ECU harness. The rest is optional and up to you. I recommend trying to find a set of the engine side clips but you can use some really small spades as a last resort. If you still have the H22 engine harness just cut the clips off for the Vtec solenoid and pressure switch.
tofastgsr
Engine Management and Tuning
Oct 26, 2012 06:11 AM
mills7x
Apr 2, 2012 11:29 AM
prime-R
Apr 4, 2009 07:34 PM
fatpride111
Sep 19, 2008 05:27 PM
Mr. Roboto
Oct 27, 2006 05:03 PM
