valve adjustment..
Old Apr 3, 2008 | 07:19 PM
2Point3's Avatar
Default valve adjustment..
i was just wondering if a valve adjusment would affect piston to valve clearance?
Old Apr 3, 2008 | 07:23 PM
vinuneuro's Avatar
Default Re: valve adjustment.. (2Point3)
It will if the valve lash is set too tight. And in case you're not already aware of this, p/v clearance should be checked with vtec lobe locked.
Old Apr 3, 2008 | 07:50 PM
2Point3's Avatar
Default Re: valve adjustment.. (vinuneuro)
yea i locked the vtec lobe when i clayed my motor.
Old Apr 4, 2008 | 07:32 AM
mgags7's Avatar
In case you were wondering, if its close enough to where the valve adjustment makes or breaks the clearance, its too close.
You should account for a normal valve lash when doing your claying, go too big to make clearance and you'll lose lift, go too small and you'll ride the valves open. Neither is any good.
Old Apr 4, 2008 | 12:25 PM
2Point3's Avatar
Default Re: (mgags7)
when i clayed the motor it had .050 clearance, do you guys think it will be safe, i adjusted the valves yesterday and they seemed a little tight.
fwdupree
Jun 1, 2018 12:13 PM
NEDan
Honda Fit
Aug 4, 2017 06:30 AM
supersize
Jul 26, 2010 11:50 PM
pr3lude1992
Apr 1, 2009 05:33 AM
