Odd engine noise...
Old Mar 30, 2008 | 08:31 AM
92ludef22's Avatar
Default Odd engine noise...
I have an AEM intake and as you all know when you step on the throttle it makes that sucking sound but the other day (only head this on two seperate occasions), it was making a loud whining noise, sounded like a turbo at high rpms, when I slowed down the whining subdued, when i stepped on it, it got extremely loud, possibly a cut in the intake?
Old Mar 30, 2008 | 08:36 AM
mattsnooz's Avatar
Default Re: Odd engine noise... (92ludef22)
Get a sound clip if possible. I bet I could figure it out.
My car's made every noise in the book.
I'd start with a spray bottle of wd-40 and LIGHTLY mist in certain areas and see if your idle changes (hold your throttle open untill you hear whinning than spray at connections and even try your intake manifold gasket.
Or listen through a long hallowed tube, have someone rev your motor and use the tube to help locate where the noise is comming from.
Old Mar 30, 2008 | 09:16 AM
DoWnfall's Avatar
b series motor?
92ludef22's Avatar
Default Re: Odd engine noise... (mattsnooz)
Will do, I will keep your name on file cause like I said I have only heard it twice and I have had the car for about 6 months now, when I hear it again I will try to diagnose it ASAP, and PM you.
Old Mar 30, 2008 | 09:17 AM
92ludef22's Avatar
Default Re: Odd engine noise... (DoWnfall)
no F22a1
Old Mar 30, 2008 | 02:53 PM
typeS's Avatar
My f22 sounds like a turbo, its just the suction at the throttle body though and its not very audible while driving.
jr408
Mar 19, 2008 09:18 AM
ae_turbobabie
Jun 21, 2004 04:24 PM
unltdacc12
Apr 4, 2003 07:54 AM
SiKSiR
Mar 16, 2002 10:16 PM
