Auto Trans problem.
Old Mar 29, 2008 | 02:51 PM
mike3's Avatar
Default Auto Trans problem.
I just bought an automatic 1990 Prelude for the gf. I bought it with this problem, and I can't seem to figure it out. When you start driving everything is good, then after about 5 minutes, out of no where it feels like it goes into neutral, and the rev's go up, but you don't move at all. It gets more [freak]ed up from here. If you turn off the car, and let it sit for a minute, once you start it you can start driving again, but it won't last as long.
The longer the car sits, the longer you can drive without this happening, to a max of about 5 min. If this happens, and you turn the car off and start it up really fast you can drive for about 10 seconds...
I've checked the ATF, and it's full. Looks a little dark, but not too bad. The S3 light on the dash is flashing too. The engine light is on, but I checked the CEL, and it's for air intake temp sensor.... I don't have a clue whats wrong..... Maybe the Auto trans module? maybe a selenoid? Any Ideas??
Thanks
BTW I have been searching for 2 days before I decided to post.
Old Mar 29, 2008 | 03:06 PM
nemesis25's Avatar
Default Re: Auto Trans problem. (mike3)
If I were you, I would drain the fluid out and refill with genuine Honda ATF. It's the cheapest and easiest to start with.
Old Mar 30, 2008 | 06:34 AM
mike3's Avatar
Didn't work. Any other suggestions?
Old Mar 30, 2008 | 08:19 AM
vinuneuro's Avatar
Default Re: Auto Trans problem. (nemesis25)
Don't check the atf level. Replace it. If you have the problem after doing so, the car needs a new trans. From what you describe it sounds like it's slipping.
4doorpowa
Oct 17, 2011 04:21 AM
94 civic d15
Jul 29, 2010 09:14 AM
JuVi ReX
Apr 3, 2010 03:10 PM
quick gixxer
Feb 5, 2008 02:04 PM
jst
Jan 16, 2007 04:09 AM
