h22a4 help please...
Old Apr 7, 2008 | 08:13 AM
drew1987's Avatar
Default h22a4 help please...
i have a 97 h22a4 and i wanted to put new piston in without re-selving the block and i was wondering if i can just buy regular h22 type-s piston from honda in put in.would it work or is there something else i have to do to put them in..help
Old Apr 7, 2008 | 08:16 AM
117's Avatar
117
To properly install pistons, the block will need to be honed, especially if the block has quite a few miles on it.
You won't be able to buy the Type S pistons from a US dealer.
Old Apr 7, 2008 | 10:23 AM
gstrudler's Avatar
Default Re: h22a4 help please... (drew1987)
There are several manufactures that make pistons for the H22A4 as well that don't need to be sleeved, such as Mahle, Jun, and JE, I believe.
Old Apr 7, 2008 | 10:36 AM
117's Avatar
117
The block still needs to be honed, regardless of the piston manufacturer used.
Old Apr 7, 2008 | 01:28 PM
drew1987's Avatar
Default Re: (117)
can i ask why it needs to be re-honed wouldnt aint it the same has boring it..?
Old Apr 7, 2008 | 06:26 PM
117's Avatar
117
Boring and honing are two completely different machining operations.
Old Apr 8, 2008 | 05:58 AM
mltv's Avatar
Default Re: (117)
boring would be the process of removing material, in your case i you bore you will need to go to the next size, being 87.2 or something like that. that means they will remove about .1 mm per side of each cyclinder, meaning they will remove .2mm in total.
Honning would be what happens after the boring process or in any situation where you want to improve the surface quality. Honning will make corrections to the surface evening out the peaks and valleys on your cylinder walls so your rings can have a smoother surface to seal against.
the best advice is to hone if your on a budget, but since the motor is out of hte car
take your time and see whats wrong what things you need to change, and what are your best solutions....Take it from me I learned the hard and expensive way
beside the H22a is an Interference engine... start with and it will tell you about the Type S pistons.
Old Apr 8, 2008 | 09:28 AM
drew1987's Avatar
Default Re: (mltv)
well i had talk to some guys that actually work on h22 and they had said it would be ok to drop them in without doing anything to the cylinder walls...
Old Apr 8, 2008 | 12:35 PM
98vtec's Avatar
moderator emeritus
Default Re: (drew1987)
then do it and dont listen to us.
Old Apr 15, 2008 | 07:30 AM
drew1987's Avatar
Default Re: (98vtec)
thanks for the input but ill just put them in...
Old Apr 15, 2008 | 10:27 AM
Finest's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drew1987 &raquo;</TD></TR><TR><TD CLASS="quote">thanks for the input but ill just put them in...</TD></TR></TABLE>
Let me know when you're ready to part that motor out in a month or so. I need an H22a head. KTHXBYE!
Old Apr 15, 2008 | 01:22 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drew1987 &raquo;</TD></TR><TR><TD CLASS="quote">well i had talk to some guys that actually work on h22 and they had said it would be ok to drop them in without doing anything to the cylinder walls...</TD></TR></TABLE>
Ask them about the FRM. If they dont know what you're talking about then maybe you should listen to us instead...
Ryhaz
10
Jan 14, 2014 07:57 AM
All-Motor-Junkie
Oct 15, 2006 03:38 AM
SnOOpY-NO
Jan 12, 2005 08:09 AM
SMOOTH97LUDE
Nov 26, 2003 08:47 PM
