Coolant problem. (Searched)
Old Apr 8, 2008 | 05:35 PM
shadow29485's Avatar
Default Coolant problem. (Searched)
I'm having some issues trying to find a coolant leak.
It's not coming from the top of the engine compartment, it's completely dry, around all of the hoses that I can visually see.
It seems to be coming from around the bottom of the trannys bell housing....I'm assuming above the housing, but I can't tell.
The weird thing is, that it doesn't really drip/leak unless I push the engine a little hard. And when I meen hard, I meen like gunning it to get in front of someone.
I cleaned the engine compartment, and pressure washed the under belly of the engine/tranny, and I can barley see a small drip of anti. freeze, like I said located on the bottom of the tranny, but it sucking my reserve dry about every other day or so.
Any ideas?
Thanks....
Old Apr 8, 2008 | 05:45 PM
Giant_Bean's Avatar
Default Re: Coolant problem. (shadow29485)
there is a coolant hose that runs under the distributor and goes into the head, might be that one.
Old Apr 8, 2008 | 05:48 PM
Hawkze_2.3's Avatar
Default Re: Coolant problem. (Giant_Bean)
/\/\/\ Yeah, check under the distributor and in the thermostat area...there's multiple hoses on the thermo housing.
Old Apr 8, 2008 | 06:00 PM
Default Re: Coolant problem. (Hawkze_2.3)
Thanks man,
I'm sorry, but I failed to give the following info. in the thread.
Idle boosts to 2000-2500 rpm while carnking back up, with engine still warm.
Idle maintains 1100 rpm and sometimes fluctuates to 1300-1400.
NO surge or pulse, indicating the fitv or aicv. Vacuums fine.
I'm also 100% sure that the thermostat is bad. Before I found the leak and realized it, she ran hot, one time, and the guage didn't register it over heating the engine.....
Old Apr 10, 2008 | 05:49 PM
I found the leak.
Heater hose, right under the clamp. Thanks GOD.
The only way it jumped out at me, was one morning I had the defrost on high and upd the hood. It was a small pin hole leak, that I never would have found, unless it was 45 degrees outside with the heater on.
crazyhouse2011
63
Apr 27, 2014 11:31 AM
Ayashifx55
Dec 23, 2010 10:01 PM
xTimmyx
Aug 29, 2010 12:28 AM
Toe_Knee
Jan 29, 2008 10:19 AM
jvonb
Dec 2, 2005 03:15 PM
