h23a1 problem and question.
Old Aug 21, 2008 | 07:10 PM
devious's Avatar
Default h23a1 problem and question.
Friends prelude was taken to honda and they said there was gas in his engine and only running on 3 cylinders. Is this motor done or can it be easily fixed or should he just get a new block and head?
Old Aug 23, 2008 | 08:01 PM
juniorlude's Avatar
Default Re: h23a1 problem and question. (devious)
needs a new engine. itll be cheaper to swap one in than to fix it.
Old Aug 24, 2008 | 02:03 PM
devious's Avatar
Default Re: h23a1 problem and question. (juniorlude)
Cool know any places that sells engines and that can put them in around the nor cal area?
Old Aug 24, 2008 | 02:10 PM
Hawkze_2.3's Avatar
How does the poster above know that you need a new engine just from one sentence you wrote?? Give us more details, look into the engine yourself, and/or take it to a shop and actually figure out what's wrong before you try to buy a new engine.
What if you just have a bad spark plug and you don't use your brain and end up paying for a whole engine?
Old Aug 25, 2008 | 11:10 AM
devious's Avatar
Yea well i said we took it to Honda and they said it was running on 3 cyliners and had gas in the engine.
But when we drive it it doesnt idle has a little knock but feels like it has same power as it always had.
Old Aug 25, 2008 | 11:20 AM
street_ride14's Avatar
Default Re: (devious)
This is retarted, the Honda dealership obviously don't know or don't want to help you. How would they diagnose gasoline in your engine ? Don't be stupid and take it somewhere else for a diagnosis before buying a new engine.
Old Aug 25, 2008 | 02:29 PM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by devious &raquo;</TD></TR><TR><TD CLASS="quote">Yea well i said we took it to Honda and they said it was running on 3 cyliners and had gas in the engine.
But when we drive it it doesnt idle has a little knock but feels like it has same power as it always had.</TD></TR></TABLE>
Yes, I already read what you said and it sounds retarded. You just repeated yourself.
Go get another opinion other than 'it has gas in the engine and it runs on 3 cylinders'....that means nothing.
Old Aug 25, 2008 | 03:06 PM
devious's Avatar
Ok I will do that thanks for the advice. Ill post again on what they say.
Old Aug 26, 2008 | 09:41 AM
juniorlude's Avatar
Default Re: h23a1 problem and question. (Hawkze_2.3)
Yeah...sorry I just jumped to conclusions when I read that. For some reason i automatically assumed that you had lost compression on one cylinder and only had 3 cylinders running. Sorry...won't let it happen again. But yeah listen to what everybody else said.
Old Aug 27, 2008 | 01:09 PM
REDLUDE4WS's Avatar
one of your cylinders, has either no compression, or no spark. simple as that. if you don't have a compression tester, pull of plug wires one by one ( unless you know which cylinder it is) and check for spark. if no spark, then you have big problems
Marshal kokogyi
Apr 4, 2017 07:31 PM
Apetrashov
Dec 1, 2016 04:56 PM
moubrco
30
Oct 27, 2012 06:32 AM
danny_379
Feb 20, 2010 12:19 PM
smithenhiven
Dec 27, 2006 09:22 AM
