ABS Problem
Old Aug 12, 2008 | 10:46 AM
paniaguae640's Avatar
Default ABS Problem
I have a 94 honda prelude si and I got a code of 10- which means pump motor- over run. I heard that to fix this you have to get a new ABS Pressure switch. The Abs light goes on after 20 seconds of driving and I can hear a whining noise and then the light comes on. What I wanted to know if this was correct on the part I need to replace? And if so where can I buy one? Kragen doesn't seem to have some.
Old Aug 13, 2008 | 06:28 PM
m00nr0ck Si's Avatar
Default Re: ABS Problem (paniaguae640)
I have the same problem so I would like to know as well
Old Sep 2, 2008 | 04:25 AM
nickcrx23's Avatar
i have the same problem, so i checked the sensors they appered to be fine so, i'm going to replace the abs pump and actuator which has the pressure switch inside. once ii have done this i will repost and let u know.
nickcrx
Old Sep 2, 2008 | 06:38 PM
Default Re: (nickcrx23)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nickcrx23 &raquo;</TD></TR><TR><TD CLASS="quote">i have the same problem, so i checked the sensors they appered to be fine so, i'm going to replace the abs pump and actuator which has the pressure switch inside. once ii have done this i will repost and let u know.
nickcrx</TD></TR></TABLE>
let us know
Old Sep 3, 2008 | 03:21 PM
Apex1972's Avatar
Default Re: (paniaguae640)
read this one
https://honda-tech.com/zerothread?id=241713
Old Sep 5, 2008 | 04:09 AM
nickcrx23's Avatar
Default Re: (Apex1972)
hi all i am glad to let you know that the ABS pump/acumulator HAS fixed my problem. any questions just ask.
hope this helps you all.
to bleed the pump i used a jumper wire on the motor relay, in the fuse box. for about 8sec then opened the nipple on the pump ( becarefull high pressure) to release the air done this 3 times, you should hear that the pump is louder than before. refitt relay and bleed the rest of the brakes at the calipers.
clear fault by removing 15amp fuse b2 for 3-5sec, refit and check abs.
Nick
Old Sep 5, 2008 | 09:58 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nickcrx23 &raquo;</TD></TR><TR><TD CLASS="quote">hi all i am glad to let you know that the ABS pump/acumulator HAS fixed my problem. any questions just ask.
Nick
How much did all the parts you needed end up costing you? Thank you for your help
Old Sep 5, 2008 | 11:06 AM
nickcrx23's Avatar
hi dnt knw how much the parts came to, as i was fixing it for a mate. but i'll find out.
oh i'm from the uk
MilanoRedDashR
Sep 8, 2011 01:29 PM
CHiNkStEr
Jul 22, 2011 08:42 AM
Marcg611
Sep 19, 2009 01:14 PM
1-slo-2-cam
Jan 11, 2006 05:33 PM
