Distributor cap spring
Old Aug 15, 2008 | 01:10 PM
dvp95's Avatar
Default Distributor cap spring
Do all distributor caps have a spring that goes to the internal coil? I have a 98 prelude and not sure if it has one. My car drives fine without it. I have a coil from an f22 but not sure if I should put it in or not. Thanks
Old Aug 15, 2008 | 07:32 PM
dvp95's Avatar
Default Re: Distributor cap spring (dvp95)
No one knows if you need the spring that goes from the inside of the distributor cap to the tower of the internal coil? The helm manual for the accord had a picture of the spring but the helm for the prelude didnt have one. Not sure if its needed
Old Aug 17, 2008 | 06:25 PM
TheJGB3's Avatar
All USDM 5th gens have an EXTERNAL COIL
Modified by TheJGB3 at 7:48 PM 8/17/2008
Old Aug 17, 2008 | 10:07 PM
dvp95's Avatar
Default Re: (TheJGB3)
I know that, mines jdm. Do all caps for internal coils have that little spring that goes from the tower of the coil to the cap? Is it necessary? My f22 accord engine had it but I cant find the one for this h22 and im not sure if i lost it or it doesnt have one.
Old Aug 18, 2008 | 06:20 PM
drbenne's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheJGB3 &raquo;</TD></TR><TR><TD CLASS="quote">All USDM 5th gens have an EXTERNAL COIL
ASE certified and that's all you can come up with??
I'm not sure if all caps have it but mine did off of a jdm h22. When i bought a replacement coil from a civic si it came with the spring. I think it helps to maintain constant continuity between the coil and the rotor.. i could be wrong though.
Old Aug 18, 2008 | 07:10 PM
dvp95's Avatar
Default Re: (drbenne)
The reason im asking is because about a week ago my h22 stopped working and I was getting no spark. I had an msd digital 6+ and ss coil at the time. I always wanted to take that off so I went back to an internal coil and put in a new ICM. that cap was the old jdm cap but was missing the spring (or doesnt have one???) so I used the one from my f22b1. My car worked with the new ICM. But only about 2 days later it stopped working. So I swapped in a new ICM and took out the spring and now its been working for a few days. So either:
1. I got a bad ICM from the box
2. Spring has something to do with it
3. Distributor is bad and the new ICM will go bad eventually.
hatcht9x
Mar 20, 2014 05:34 PM
dave n
Nov 20, 2013 10:41 AM
IndySporty
Jul 27, 2010 01:19 AM
lsvtec_hatchback
May 22, 2006 07:43 PM
brockscivic
14
Mar 22, 2006 05:58 AM
