eclipse injectors
Old Aug 21, 2008 | 08:30 PM
malangi's Avatar
Default eclipse injectors
i just got a dumb "?" sorry if its already posted but i'm looking for injectors for my turbo h22a JDM and one of my friend told me that i can use injectors off of 95 eclipse 2.2L TURBO(480cc) can anyone tell me if that's true or not and where can i find the ecu chip to go with it
any help will be appreciated, thanks
Old Aug 22, 2008 | 06:24 PM
Mervin's Avatar
Default Re: eclipse injectors (malangi)
you can use DSM injectors of the 4G63 engine.
These cam in EVO's, Talon's, Eclipse (turbo models)
you have blue top and black top injectors and they are 450cc and some are 550cc Difference between blue and black: blue is dual spray pattern aimed at individual intake valves
Black is single spray (as is OEM)
You need an resistor box ....OBD1 style
hope this helps
Old Aug 22, 2008 | 07:42 PM
malangi's Avatar
thanks a lot
i don't really know much about this stuff
now that i kknow about injectors can you also tell me which ECU should i get for it to work with my turbo setup??
Old Aug 23, 2008 | 06:48 AM
REDLUDE4WS's Avatar
you can use these injector but they are not plug and play, i will ell you that for sure. when i did my h22a4 swap all i had for injectors (peak and hold ones anyways) were my stock 240 cc h23 squirters. my buddy has what is called laser (4g63T motor) and i "stole" (thanks jonny) his injectors. modify, modify, modify. all i have to say is use the spacer in manifold, dremel it so it fits around nozzle of 440cc injector, use the rubber base from stock injector, and make a 1/8" to 3/16" washer to push against the rubber seal. i used some pcv piping from a mop handle or some **** like that. mock it up and make it up. ps don't just shove injectors in because people think you can use talon injectors. figure out how much power you will make (really make, not what you think it will make) and figure out what size you need. not all turbo setups should be treated as equals. peace.
suthernbred904
Oct 14, 2009 07:21 AM
Cole89ef
Aug 13, 2009 11:10 PM
AJxr
22
Dec 31, 2005 12:40 PM
kr
Feb 27, 2005 07:33 PM
Kidd_Stylez
Dec 23, 2003 04:25 AM
