01 prelude stall problem
Old Aug 19, 2008 | 06:50 AM
joshblaze101's Avatar
Default 01 prelude stall problem
ok my 01 prelude just started to have a problem stayin runnin when im not givin it gas/it wont idle.....runs fine as long as im pressin the gas as soon as my rpms drop like below 1500 it putters out and stalls? wtf. lol not fun
Old Aug 19, 2008 | 08:01 AM
MJOLNIRvTEC's Avatar
Default Re: 01 prelude stall problem (joshblaze101)
check egr, iacv, and maybe try doing this http://92lude.com/idle_air_control_bypass_mod.htm. hope it helps man. gluck
Old Aug 19, 2008 | 02:53 PM
bluedlude's Avatar
Default Re: 01 prelude stall problem (MJOLNIRvTEC)
sounds like a problem with the injectors or the IACV as MJ stated
Old Aug 20, 2008 | 08:44 PM
ok so i was told including the stall problem the pingging from my motor could be a valve problem i ran the codes from the check engine light n ....4 of wich were miss fires....so i was told could be my valves wich is the noise n the stalling on low rpms so i take off the valve cover didnt see ne thing out the the ordanary i put the cover back on but dont bolt it down n its stays runnin bad o2 sensor...dude im lookin 4 ne thing
twinludes
Dec 26, 2010 01:26 PM
Mad Third Gear Vtec
Sep 3, 2010 04:48 PM
bigmike321321
Mar 27, 2007 06:01 PM
ian[-]
Aug 26, 2006 06:18 AM
KeRRMiNaTioN
Acura TL, RL & ZDX
Oct 28, 2003 03:21 AM
