over heating
Old Aug 19, 2008 | 09:48 AM
bjones's Avatar
Default over heating
i have a 92 prelude si, the other day while i was driving i noticed the temp gauge go past halfway, so i turned on the heat in the car and it immediately went back to half. so i get home and pop my hood to check for cracks in radiator hoses,etc. then i check the fuse box and the cooling fan relay is missing. so i grabbed an extra one i had laying around and put it in the correct spot. with the car off the fans immediately kick on. then i go and start the car and the fans turn off. then if i turn my car off. the fans turn right back on, and if unplg the fan switch by the upper radiator hose(the green connector) the fans will stop. fans will turn on when car is off but not when on, car still overheats occasionally and it sucks cuz i have to drive around with the heat on. any ideas??
Old Aug 19, 2008 | 09:55 AM
street_ride14's Avatar
Default Re: over heating (bjones)
Flush coolant and refill, remove and replace thermostat, bleed the air in the system, and then get back to us.
Old Aug 19, 2008 | 10:20 AM
Hawkze_2.3's Avatar
Either the relay is bad or the fan switch is bad if you ask me...or you have a wiring problem.
Old Aug 19, 2008 | 10:37 AM
bjones's Avatar
Default Re: over heating (Hawkze_2.3)
ya i was assuming a fan switch, any way to verify that before i buy a new one, and the relay i replaced the missing one with was off my gsr. it was working at the time i pulled the motor.
Modified by bjones at 1:45 PM 8/19/2008
Shade93
Apr 13, 2010 01:15 PM
Fighterinsnatch
14
May 26, 2007 08:18 PM
Dual_Phart_cans
33
Jul 25, 2005 09:12 AM
4U2NV
Jun 14, 2004 11:46 AM
