92 just started
Old Aug 16, 2008 | 10:00 PM
sillyd71's Avatar
New User
Default 92 just started
hey i just bought a 92 prelude si 2.3 non vtech just looking for some ideas on upgrades (im ballin on a budget) but i already have a dnx headers and aem intake so ne more options im open to thanks for ne ideas
Modified by sillyd71 at 7:38 PM 8/31/2008
Old Aug 16, 2008 | 10:12 PM
98vtec's Avatar
moderator emeritus
Default Re: 92 just started (sillyd71)
nothing worth anything wont kill your wallet.
Old Aug 17, 2008 | 04:10 AM
mattsnooz's Avatar
Default Re: 92 just started (98vtec)
heheheheh.
Just save up 4-6 grand and turbo it.
honestly though, if your on a budget you don't want to be doing performance stuff just yet. Start with routine maintenance stuff like brakes, fluid changes, filters, and by doing such familiarize yourself with your car.
Buy a hanes or equivilent shop manual for your 4th generation prelude 1992-1996 years will cover your car.
With any money left over after doing regular maintenance work on your car, pocket it or bank it. Things will go wrong with your car so its good to keep a 1000 dollar buffer to repair them when they do.
When you get 2 grand in the wallet, than start installing performance parts. At this point though you need to start planning your goals and make sure you aren't buying redundent parts that arn't going to support your future goals thus being wasted money.
READ READ READ before you start doing any mods or upgrades too. Than any questions after you've read things, than post here seeking clarification.
Old Aug 31, 2008 | 06:36 PM
sillyd71's Avatar
New User
Default Re: 92 just started (mattsnooz)
hey thanks for the advice i found out it has a few after market parts already but how would i find out like if the computers had ben messed with i know it has dnx headers aem cold air intake and a few other things and it is idols high then drops to under a grand and shoots back up to like 3 grand i think it just the computer
Old Aug 31, 2008 | 07:06 PM
97ludedude's Avatar
there is a couple of things that could be. First make sure that the throttle cable isn't too tight. You should some play in it. Second, the idle air screw it the front of the throttle body, at the top. make sure no one has messed with this. it should have a grey coating on it. If it has been messed with try screwing it all the way in. Also, A bad vacuum leak can make it "idle roll". check vacuum lines and also the intake manifold gasket.
Old Dec 19, 2008 | 10:30 PM
sillyd71's Avatar
New User
hey also i have a new puzzle lol i just put a new set of headers on and now i have this nasty lil grinding in my motor i can feal it in my gas pedel but it feals like somthing grinding the ground ne ideas are thanked
00Luder
Feb 19, 2007 12:59 PM
Fajin
May 27, 2004 02:06 PM
K Kendall
May 10, 2002 07:25 PM
