head work
Old Aug 15, 2008 | 01:34 PM
2000h22a's Avatar
Default head work
i didnt think this should go in the cam section of the faq because it really doeset fall under that category, but here goes..
when i upgrade my cam (to a crower stage 2) and look to get new valves, springs, and retainers, it says do not use titanium retainers with a daily driver, why? also it says not to use the cam with oversized valves, why? shouldnt i be okay with a valve thats .050 over with the cam? or is there an issue that i dont know about. head will be going on a 00 base h22a4, port and polish will be done and crower cams with crower springs retainers and valves. aem cam gears, s2 IM, 68mm tb, aem cai etc
thanks in advance
Old Aug 16, 2008 | 07:35 AM
Mikey3000's Avatar
Default Re: head work (2000h22a)
prolly because titanium isn't as resillient as steel. with oversized valves and the high lift cams, you may get valve to valve interference.
Old Aug 16, 2008 | 11:40 PM
2000h22a's Avatar
Default Re: head work (Mikey3000)
so steel retainers, and the stock size valves? sound good?
Old Aug 16, 2008 | 11:47 PM
vinuneuro's Avatar
Crower cams haven't been especially impressive, at least with the H22's. Nothing seems to out do the Skunk2 Pro series cams. If they're over your budget, save for them.
Titanium retainers will be a wear item.
Old Aug 17, 2008 | 12:08 AM
2000h22a's Avatar
Default Re: head work (vinuneuro)
ive actually heard good things about the crowers but i did take a good long look at the s2's, any suggestions on the retainers?
Old Aug 17, 2008 | 12:22 AM
vinuneuro's Avatar
Search Skunk2 Pro series and Crower dyno's. The pattern of results will be pretty obvious from the beginning. Buying parts because you heard they're good is a bad way to go.
Supertech makes good valvetrain.
Old Aug 17, 2008 | 12:35 AM
2000h22a's Avatar
allright, yeah im on supertech's site now, im seeing ferrera aluminum/magnesium retainers on importperformanceparts.com, but nothing other than that and the titanium ones.
Old Aug 17, 2008 | 12:47 AM
vinuneuro's Avatar
Supertech, Ferrea, Rocket are all good options. Contact one of the sponsors (search the Sponsor forum) for Supertech and Ferrea, and you can contact user Aquafina for Rocket.
Old Aug 17, 2008 | 08:20 AM
2000h22a's Avatar
thanks!
B18B1-Crx
Apr 2, 2010 06:08 AM
Nors
Mar 29, 2007 05:40 AM
ChickenH
Mar 4, 2007 08:53 AM
kwik93si
May 2, 2003 03:58 PM
