knocking noise
Old Aug 30, 2008 | 01:56 AM
accord2civic2prelude's Avatar
Default knocking noise
ok..92 prelude...just changed the power steering belt and a ticking noise started. It only happens at idle at first start until engine warms up. what could it be? i looked to see if anything was loose or hanging and nothing. any suggestions?
Old Aug 30, 2008 | 07:20 AM
REDLUDE4WS's Avatar
Default Re: knocking noise (accord2civic2prelude)
the belt deflection on these belts has to be pretty tight, alot more so than normal application. try tightening belt if you see best fit. are you sure it is sitting on pulley properly?
Old Aug 31, 2008 | 10:12 AM
superflow's Avatar
your oil pressure could be low, other than that, check ur bearings and see if anything is wrong with them.
Old Sep 2, 2008 | 07:34 AM
REDLUDE4WS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by superflow &raquo;</TD></TR><TR><TD CLASS="quote">your oil pressure could be low, other than that, check ur bearings and see if anything is wrong with them.</TD></TR></TABLE>
what, are you on the same thread dude? explain bearings, pretty broad statement. anyways......
therhett17
Mar 3, 2015 04:06 AM
bpetruzzo
24
Jul 30, 2011 03:47 AM
Nataku
Jan 5, 2006 07:31 PM
kihun_cha
Oct 17, 2004 10:57 PM
808style
Jul 31, 2003 12:37 AM
