Noisy Air Compressor
Old 08-27-2008, 06:50 AM
mcasarez's Avatar
Default Noisy Air Compressor
I have a 1994 Honda Prelude Si with a very noisy air compressor. It makes a huge whining noise. The A/C blows cold air, but the noise is loud and quite embarrassing. Where should I look for the cause of the problem? How can I fix this?
Old 08-27-2008, 07:28 AM
Acidcrakker's Avatar
Default Re: Noisy Air Compressor (mcasarez)
Your Wheels are squeeling. Could be the belt. You can try belt dressing, or pos WD40 to see if it stops. But dont squirt the belt with WD40.
Old 09-03-2008, 10:30 AM
doeboi365's Avatar
Default Re: Noisy Air Compressor (Acidcrakker)
my car is doing that too would it be the bearing in side the pulley?
Old 09-03-2008, 10:36 AM
mcasarez's Avatar
Default Re: Noisy Air Compressor (doeboi365)
I have heard it is either the belt or the bearing in the pulley. I have also heard that if it is the bearing in the pulley, it might be best to replace the compressor. I haven't taken it in for a diagnostics yet. I know a/c work is very expensive.
Old 09-03-2008, 07:53 PM
TheJGB3's Avatar
If it is the bearing in the clutch/pulley assy, then just replace the clutch/pulley assy. That way no evac/rechg to the system save $$.
Old 09-04-2008, 11:21 AM
REDLUDE4WS's Avatar
Default Re: (TheJGB3)
bearings tend to whine/drone/annoy, clutch assy is definately the way to go as well while it's apart. i have about 5 of these ac comprssors in the shop that are known to be good. make an offer if you like, but i'm situated in canada. these comprssor in canada go for about 500 easy new
Old 09-10-2008, 07:11 PM
doeboi365's Avatar
Default Re: (REDLUDE4WS)
okay sooo i did the belt on the ac and all and took that pully out and sprayed sum lubricant on it and it is no making this screeching noise now when i shift gears tensioner to tight i think??? idk....
Old 09-11-2008, 08:05 AM
REDLUDE4WS's Avatar
Default Re: (doeboi365)
does the pulley line up with the alt and crank? honda belt need to be stoopid tight usually not to squeal. might be the other way around, try tightening...maybe?
fragmare
06-25-2013 04:54 AM
Drazz
05-01-2013 06:57 AM
nicanbeastfool
05-22-2012 04:24 PM
Rok_Stok
04-10-2010 01:03 PM
barkwaffle
08-12-2005 05:53 PM
Quick Reply: Noisy Air Compressor
