H22 Heads, do they differ?
Old Sep 7, 2008 | 03:29 AM
lockstock's Avatar
Default H22 Heads, do they differ?
I have an H22a motor fitted in my civic, unfortunatly the head gasket has just gone.
I've got a spare h22 head but I don't know what model motor it came from. I thought instead of sending the one attatched to my engine to be skimmed, I could just use my spare one.
I guess my question is are all h22 heads the same?
thanks
Old Sep 7, 2008 | 06:22 AM
Acidcrakker's Avatar
Default Re: H22 Heads, do they differ? (lockstock)
As long as its a H22a head it should be the same. Why dont you just get a new head gasket?
And by skimming the head do you mean milling?
Old Sep 7, 2008 | 06:38 AM
lockstock's Avatar
Its an H22 head but I don't know if it came from a UK car! Is there any difference between the UK/US and import heads?
And yea I mean milling
Old Sep 7, 2008 | 07:01 AM
vinuneuro's Avatar
Default Re: (lockstock)
Not all H22 heads are the same. The Type-S and EuroR heads are hand-polished from the factory. There's also speculation that the 98+ (code PCF) heads have a better casting finish.
Old Sep 7, 2008 | 08:42 AM
twinksack's Avatar
* B A N N E D *
Default Re: (vinuneuro)
any h22 head will fit any h22 bottom end
Old Sep 7, 2008 | 12:14 PM
gstrudler's Avatar
Any head should fit if that is all you are looking for. As vinuneuro stated, however, some of the heads have better flow characteristics. If you don't know where your other head is from, I would probably suggest pulling your known head off the block and getting it milled.
Old Sep 7, 2008 | 02:15 PM
Apex1972's Avatar
Default Re: H22 Heads, do they differ? (gstrudler)
Just make sure you buy the correct headgasket. If you have a H22A bottom end, buy that gasket. If you have an H22A4 bottom end, buy the gasket for the H22A4.
CA121
12
Mar 11, 2011 12:10 PM
Heads by Drew
Oct 21, 2008 04:12 PM
RACING INTEGRATION
Oct 23, 2005 07:59 PM
