timing issue help!!!
Old Aug 31, 2008 | 09:28 AM
h23prelude94's Avatar
Default timing issue help!!!
ok i have a 94 prelude si with a h23 in it..i took it in for inspection and when it was on the dyno for admissions it had a hickup a small missfire.....so i changed the plugs wires rotor n cap n it got alot worse...n now its backfiring through my intake....how do u think my timing jumped off by changing the igniton wires etc. and i tested the ignition its coming from somewhere else?
Old Aug 31, 2008 | 10:25 AM
Hawkze_2.3's Avatar
Default Re: timing issue help!!! (h23prelude94)
Make SURE you got the wires in the right order and then double check your timing with the cam gears and flywheel marks.
Old Aug 31, 2008 | 06:07 PM
Default Re: timing issue help!!! (Hawkze_2.3)
ya i did i counted them n the wires r in th rite order...i did mor tests u think mayb a bent valve? i did fuel cleaner n ran the same?
Old Aug 31, 2008 | 07:09 PM
97ludedude's Avatar
check your plug wires again. . . i bet two of them are crossed
Old Aug 31, 2008 | 07:12 PM
MJOLNIRvTEC's Avatar
Default Re: timing issue help!!! (97ludedude)
also make sure you didnt rotate your dizzy too much,i think ive read something on here about how every 8th inch of rotation affects timing.
Old Aug 31, 2008 | 07:20 PM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h23prelude94 &raquo;</TD></TR><TR><TD CLASS="quote">ya i did i counted them n the wires r in th rite order...i did mor tests u think mayb a bent valve? i did fuel cleaner n ran the same?</TD></TR></TABLE>
Translation?
Old Sep 1, 2008 | 08:59 AM
i checkd the dizzy n the wires theyr in the right place....i gota guy that has a h22 head for sale that came from a 97 prelude.....im almost 100% its a valve not seating properly now can i swap a h22 head on that h23 block n it will bolt up fine no tuning?
wideload
10
May 28, 2010 10:26 PM
93LsVx
15
Jun 24, 2009 04:23 AM
93-lsvtec-eh2
Apr 2, 2007 02:48 PM
Griffins_Importuning
Oct 19, 2002 06:54 PM
