h22 idle problems. please help
Old Sep 2, 2008 | 03:03 PM
dointhemzs's Avatar
Default h22 idle problems. please help
i have a 92 accord lx with a h22 swap. when i bought it the wires were all haggard and it had an idle problem. i cleaned it all up replaces all my vacuum lines and still had the same problem. Then i replaced the iac sensor. still had the same problem. when you unplug the sensor the idle stays normal. when its plugged it it revs from 1000 to 2500 rpm. im all out of ideas. also replaced all wires and plugs and all are firing. please help
Old Sep 2, 2008 | 04:17 PM
98vtec's Avatar
moderator emeritus
Default Re: h22 idle problems. please help (dointhemzs)
are you sure you are using the right connector?
the IACV has a green/white wire going to its connector.
Old Sep 2, 2008 | 05:07 PM
dointhemzs's Avatar
Default Re: h22 idle problems. please help (98vtec)
i figured it out it was the FITV
dahoopdahup
Mar 21, 2006 04:30 PM
worrdogg
Nov 4, 2004 03:09 PM
Kp_VtekNiks
18
Sep 16, 2003 12:10 AM
