What is this plug?
Old Aug 25, 2008 | 02:32 PM
MJOLNIRvTEC's Avatar
Default What is this plug?
So i was wondering where this plug should lead to. I got this car basically stripped and this wasnt hooked up. Any input? Thanks
Old Aug 25, 2008 | 02:33 PM
Hawkze_2.3's Avatar
Default Re: What is this plug? (MJOLNIRvTEC)
Coolant either goes in there or comes out there....should be another one close by.
Old Aug 25, 2008 | 02:34 PM
Default Re: What is this plug? (Hawkze_2.3)
another plug or a loose hose?
Old Aug 25, 2008 | 02:43 PM
Hawkze_2.3's Avatar
Well technically it's called a nipple, but there should be another 'plug' somewhere right there under the throttle body. It's for the FITV (do a search please) and it has coolant flowing into and out of it, thus 2 nipples.
Old Aug 25, 2008 | 05:06 PM
well ****, impretty sure there isnt another nipple. so im guessing that the fitv was removed. i dont even know where to go from here
Old Aug 25, 2008 | 05:31 PM
Hawkze_2.3's Avatar
Weird...what engine is this on? Maybe the coolant return is on the inside of the throttle body and intake manifold? You don't have a typical H22/H23 throttle body I know that much...
If the FITV was removed you wouldn't have that nipple and there would be an empty space...so it's not that
Old Aug 25, 2008 | 05:37 PM
i have an h22a1 under the throttle there are some empty groves/holes so i wonder if the fitv was removed. Its getting super irritating its like one thing after another with this car lol i wondering if i should just yank the whole thing 2morrow and investigate....and if it is removed curse the gods because i cant find the fitv anywhere...
Old Aug 25, 2008 | 05:39 PM
heres a pic, im wondering if i should just give rosko a call and get a type r mani
Old Aug 25, 2008 | 05:46 PM
i found the part at southbay honda for 77 bucks? good deal?
Old Aug 25, 2008 | 05:50 PM
Hawkze_2.3's Avatar
Can you get a pic of the bottom of the TB?
You should be able to find a used FITV on here or eBay or something for pretty cheap...I think I have some in the garage also if you want
Old Aug 25, 2008 | 05:55 PM
97ludedude's Avatar
the fast idle valve has been removed off of the bottom of the throttle body. That nipple isn't doing anything. If you look at your idle air control valve you will find the mystery missing hose. somebody has ran it from the thermostat housing to the idle air con valve to bypass the fast idle valve trying to make it run better. Hot coolant near air intake makes incoming air hotter (not much). Hotter air less oxygen. . . less power. you need to look at the bottom of the throttle body and make sure they blocked off the two holes or you will have a bad vacuum leak.
Old Aug 25, 2008 | 05:58 PM
Hawkze_2.3's Avatar
Default Re: What is this plug? (97ludedude)
So that nipple is supposed to go over to the IACV? Mine isn't set up that way, but it's an H23...
Old Aug 25, 2008 | 06:27 PM
Yeah im just goin to take the whole damn thing off 2morrow. hopefully if i can find out how to make it work ill buy a fitv from hawk and slap that biotch on there
Old Aug 25, 2008 | 06:40 PM
also there is a harness that is right above the thermostat....
is this a service port or just another lose end..that im going to need to fix. I cant find anything on the helms besides a service port
carlos8
Dec 31, 2013 03:14 AM
hotrod99
May 5, 2007 12:11 PM
VTEC Visions
Feb 24, 2005 02:25 PM
DXturbo
Jul 5, 2003 02:27 PM
TGUNNER
May 7, 2002 07:31 AM
