Pro1s or Pro2s
Old Aug 25, 2008 | 12:04 AM
92SR4WS's Avatar
Default Pro1s or Pro2s
Hey,
Okay so I have searched and searched to try to figure out whether Skunk2 Pro1 cams or pro2 cams would be better for my setup. After hours of searching I still am not to sure as there have been mixed reviews...
This is what I will have eventually. If I do Mill the head and get the thinner head gasket(not sure if I want to do this yet...) it would be around 11.6:1 CR what do you think pro1s or 2s
CAI
Esp Header and full 2.5" exaust
Deck Head (0.02)
Thinner Head Gasket (0.009)
Port and Polish
AEM Tru power pullies
Modified Stock IM
Thanks,
-Greg
Modified by 92SR4WS at 4:45 PM 9/13/2008
Old Aug 25, 2008 | 04:38 AM
autoluder's Avatar
Default Re: Pro1s or Pro2s (92SR4WS)
you might want to throw in some flat faced valves for extra compression bump. Probably wouldnt go with pro2s till you hit 12:1cr. Dont forget aftermarket valve springs and retainers. Forget the s2 intake manifold, and their tb. People have problems with the s2 tb. As for the manifold, get a couple blacktrax spacers. or one of their upgrade packages.
Old Sep 13, 2008 | 03:27 PM
92SR4WS's Avatar
Default Re: Pro1s or Pro2s (autoluder)
yeah I'm going with the RM valve train as for the valves im not sure yet yeah I've changed my mind about the S2 IM im gunna modify the stock one. So with out the valves 11.6:1 isnt enough for pro 2s? what about with valves ~11.9:1 Is that better for pro 2s???
Old Sep 13, 2008 | 06:26 PM
autoluder's Avatar
that would be a good start, yes.
Old Sep 14, 2008 | 07:39 AM
vinuneuro's Avatar
Pro2's no question about it.
Old Sep 14, 2008 | 01:43 PM
92SR4WS's Avatar
Default Re: Pro1s or Pro2s (vinuneuro)
Any other opinions???
Old Sep 14, 2008 | 04:23 PM
vinuneuro's Avatar
Instead of asking for opinions, why don't you search the All Motor forum. There are plenty of dyno's of both cams used in both H and B series apps.
Old Sep 14, 2008 | 07:11 PM
92SR4WS's Avatar
I have searched, there are not many dyno comparisons for these two cams.
Old Sep 14, 2008 | 07:12 PM
vinuneuro's Avatar
The Pro2's out-do the Pro1's in all applications and compressions.
Old Sep 15, 2008 | 05:05 PM
92SR4WS's Avatar
okay so your telling me even if I keep stock compression(10.6) the pro2 would out perform the pro1?
Old Sep 15, 2008 | 09:49 PM
autoluder's Avatar
No, Each series is progressively better, but that depends on your setup, go on skunk2's website and research, or send them an email and see what they tell you..below 11:0cr is not going to give you the maximum hp for even pro1s, thats pretty much what they told me. stock setup the tuner series stage 1 would be best.
Old Sep 16, 2008 | 05:01 AM
REDLUDE4WS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vinuneuro &raquo;</TD></TR><TR><TD CLASS="quote">The Pro2's out-do the Pro1's in all applications and compressions.</TD></TR></TABLE>
not true. read this months modified mag. project low key. pro 2 to not have the same power band pro 1's do. there are a lot of different variables involved. pro 1 were a pain in the city but made MORE power across the board. pro 2 are great DD cams but made 5whp less @ any given point on the dyno. they ran stock compression gold series mahle slugs.
Old Sep 16, 2008 | 08:07 PM
92SR4WS's Avatar
yeah thats what I thought I was actually reading project low key last night it looks pretty sick!
Old Sep 16, 2008 | 08:21 PM
streetracer6rpt's Avatar
Modified by streetracer6rpt at 12:45 AM 9/17/2008
Old Sep 16, 2008 | 11:49 PM
HdeucedeuceA's Avatar
Default Re: Pro1s or Pro2s (REDLUDE4WS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by REDLUDE4WS &raquo;</TD></TR><TR><TD CLASS="quote">
not true. read this months modified mag. project low key. pro 2 to not have the same power band pro 1's do. there are a lot of different variables involved. pro 1 were a pain in the city but made MORE power across the board. pro 2 are great DD cams but made 5whp less @ any given point on the dyno. they ran stock compression gold series mahle slugs.</TD></TR></TABLE>
I would of thought pro 1's would be better for the "street" not the pro 2's. Or did you get it backwards?
Old Sep 17, 2008 | 03:40 AM
REDLUDE4WS's Avatar
Default Re: Pro1s or Pro2s (HdeucedeuceA)
it was just what i read. i saw the charts they did make more power. i could only imagine peter tarach (editor) knows what he is talking about, he's usually pretty much on the ball from where i sit
TravG
Jan 4, 2012 07:57 PM
H-allmotorda9
17
Feb 6, 2010 07:40 PM
ThEOutSidEr
Dec 16, 2003 09:13 AM
pg_thao
Apr 22, 2002 08:44 AM
VaporTrail
Oct 18, 2001 10:40 AM
