Replacing steering knuckle
Old Nov 20, 2008 | 11:11 AM
nstory13's Avatar
Default Replacing steering knuckle
ok a quick question. I've heard that sometime when replace a steering knuckle you also need a new wheel bearing. Is this necessary? I'm wanting to know so I can order everything at once. is their anything else that I would need to order besides the cotter pins?
Old Nov 20, 2008 | 11:34 AM
E-Money's Avatar
the knuckle bent?
Old Nov 20, 2008 | 11:44 AM
nstory13's Avatar
Yep. I put it up on the rack at school because NTB said it was a bent strut on a double wishbone suspension... and my SAI was just barely off and it's enough to pull my car when i brake and accelerate
vinuneuro's Avatar
I don't think the knuckle comes with the bearing installed, so yes you need a new one. Do not reuse the one from your old knuckle.
Old Nov 20, 2008 | 11:57 AM
nstory13's Avatar
Thanks, found out its going to be like 350 bucks to fix...ouch.
Old Nov 20, 2008 | 12:00 PM
vinuneuro's Avatar
Knuckle is $215, bearing is $55. It only takes 15-20min to replace if you do it yourself.
www.hondaautomotiveparts.com
Old Nov 20, 2008 | 12:07 PM
nstory13's Avatar
sweet cheaper than the local dealership WITH a discount.
Old Nov 20, 2008 | 12:18 PM
nstory13's Avatar
I can't find the bearing on here, whats the part number?
Old Nov 20, 2008 | 12:27 PM
vinuneuro's Avatar
Look in the brakes section.
Old Nov 20, 2008 | 12:33 PM
nstory13's Avatar
there's two bearing assembly i'm guessing it doesn't matter which one i get.
Old Nov 20, 2008 | 12:43 PM
vinuneuro's Avatar
I only see one, #4.
http://www.hondaautomotiveparts.com/...y5=FRONT+BRAKE
Old Nov 20, 2008 | 12:44 PM
117's Avatar
117
If you have access to a press to install the bearing.
Old Nov 20, 2008 | 12:45 PM
vinuneuro's Avatar
Indeed. But I can't imagine a machine shop asking too much to press the bearing in.
Old Nov 20, 2008 | 12:47 PM
nstory13's Avatar
ah you have the 98 prelude selected. I guess it would have been more useful if i would have told you I have a 95 prelude
Old Nov 20, 2008 | 12:48 PM
nstory13's Avatar
I'm pretty sure we have something at my school for it. Shouldn't be a problem.
Old Nov 20, 2008 | 01:06 PM
vinuneuro's Avatar
When they list two identical parts without listing the brands, it's usually because Honda made some design change.
MotorMouth93
Jan 22, 2018 03:54 AM
88CRXOvalRacer
Suspension & Brakes
Sep 8, 2012 04:57 AM
EG_93Civic
13
Feb 8, 2006 08:01 PM
mymeatb18"
13
Dec 28, 2004 08:14 AM
EL-Driver
May 14, 2003 03:10 PM
