Clutch Info.
Old Nov 21, 2008 | 04:33 AM
dk4ever's Avatar
Default Clutch Info.
This will be my 2nd clutch in a years time. I did not excersise the "break-in" period last time and it obviously has cost me more money. I need to get it right this time. My questions are as follows.
1. How do you break-in a clutch?
2. Do I need to replace the flywheel again? I already installed a light-weight flywheel when I put the last clutch in this past February.
3. After the clutch break-in period is over. Is there a certain way you have to accelerate with an 8lb. flywheel installed? I've heard different things.
Thanks in advance.
Old Nov 21, 2008 | 03:58 PM
CivicSiDriver02's Avatar
I would suggest breaking in your clutch by doing some normal stop and go driving for a few hundred miles. I would not suggest anything in the higher RPM range during this time frame. The friction material needs to go through a heat cycle, similar to bedding brake pads for best service life. As far as the flywheel goes, you might want to see if you can get it turned to knock off any high spots or deglaze the surface. What type of flywheel is it? I have an 8lb. Fidanza in my Prelude, which has a replacable friction ring. This allows you to just replace the ring, rather than the whole flywheel. I really don't think there is any need to alter your driving style after your clutch is broken in.
Old Nov 21, 2008 | 08:45 PM
riyanadiyon's Avatar
Duleeka
Myspace web promotion
Old Nov 22, 2008 | 09:02 PM
dk4ever's Avatar
I have an 8lb. Competition Clutch flywheel. I ask about altering driving style only because I heard once you have a light weight flywheel installed you can't powershift or basically have any fun.
Old Nov 22, 2008 | 09:08 PM
vinuneuro's Avatar
Inspect the flywheel for wear. Most lightweight flywheels come with replaceable friction surfaces.
As far breaking in the clutch, just drive normally. Ie. don't be abusive. Don't launch, slip it excessively, shift at high rpm.
What brand clutch was the last one?
Old Nov 24, 2008 | 07:52 AM
dk4ever's Avatar
Exedy Stage 1
B_Swapped93
Apr 4, 2013 06:30 PM
rich7777
Jan 3, 2011 03:21 PM
Ralleh
Honda S2000
11
Oct 13, 2009 05:40 AM
Heinz57
12
May 26, 2003 04:34 AM
