Starter question!
Old Nov 15, 2008 | 01:24 PM
snzh22's Avatar
Default Starter question!
i got a used starter from an owner who said he got it tested and worked fine. at first it did nothing at all, just like my old starter. then after a couple cranks it started to make rapid clicking noises, again like how my old starter would do occasionally. then i started hitting it, an old trick i learned with my old starter, and then it finally started. basically im not sure if this is normal or not when putting on a starter that has been laying around. is it?
by the way when it finally started i saw a huge spark and then it started. spark when from the starter and shot outward towards the radiator. what happened?
it is now starting normal for the next 2 starts, but i dont know if its going to crap out on me sometime soon....
Old Nov 15, 2008 | 05:13 PM
mattsnooz's Avatar
Default Re: Starter question! (snzh22)
the solinoid is sticking by the sounds of it. You could tear it apart and *** with the solinoid, but lilkey you're going to experience the same issues at one point or another!
Old Nov 16, 2008 | 04:05 PM
snzh22's Avatar
Default Re: Starter question! (mattsnooz)
i dont really wanna tear it apart because that may just make it worse.
acted up again today...first no sounds at all when cranking. then waited a little then heard the starter trying to start with a rapid "clicking" sound. then went with the hitting trick and it started. this sucks...any other problems it could be? if theres a bad connection, where could it be?
Old Nov 16, 2008 | 04:10 PM
Darkbluelude's Avatar
mine made that clicking noise/exact same symptoms. Took it to get tested, it wasn't working. Replaced it, hasn't happened since.
ek4__
Oct 2, 2006 03:06 PM
WTB AUTO EK
May 12, 2005 06:46 AM
HXvtec
Nov 6, 2004 02:15 PM
SubTitle
Oct 30, 2003 11:04 AM
Sukebei Oni
Mar 16, 2003 01:21 AM
