Lowering Alignment?
Old Nov 12, 2008 | 03:35 PM
djcue95948's Avatar
Default Lowering Alignment?
I am lowering my 98 lude with tokico blue suspension. I have been searching around for the right ways to do alignment. Some say just get the adjustable upper ball joints and some say to get the Toe arm?? what should i do? should i just get the Adjustable INGALLS ball joints. I JUST WANNA KNOW WHAT SHOULD BE THE BEST THING TO DO SO I CAN GET MY CAR ALIGNED AND HAVE MY RIDE DRIVEN SMOOTH. PLZ LET ME KNOW. IM PUTTING ON AND DOING SO WITH MY SUSPENSION RIGHT NOW AS U READ.
ANYTHING WOULD HELP!!
Old Nov 12, 2008 | 04:26 PM
Kronn 98SH's Avatar
Default Re: Lowering Alignment? (djcue95948)
Just drop the lude and then get an alignment at an alignment shop. If something is still outta whack, THEN you need something extra. Otherwise, forget it.
Old Nov 12, 2008 | 05:40 PM
vinuneuro's Avatar
The only thing you need to adjust is toe. Don't need to buy anything extra, just get the alignment.
Old Nov 15, 2008 | 12:29 PM
djcue95948's Avatar
Default Re: Lowering Alignment? (vinuneuro)
KOOL...thanxs
Old Nov 15, 2008 | 02:58 PM
bbsprelude's Avatar
if you dont want camber ware, you'll need to get camber kits. but, depending on how low you are going and how big your wheels are, you might need the negative camber so your wheels tuck
Old Nov 15, 2008 | 10:36 PM
Kronn 98SH's Avatar
Default Re: Lowering Alignment? (bbsprelude)
Originally Posted by bbsprelude
if you dont want camber wear, you'll need to get camber kits.
not true
Old Nov 15, 2008 | 10:43 PM
ejLday's Avatar
Default Re: Lowering Alignment? (Kronn 98SH)
Originally Posted by Kronn 98SH
not true
Not true? Please elaborate...
Old Nov 15, 2008 | 11:57 PM
Kronn 98SH's Avatar
Default Re: Lowering Alignment? (ejLday)
Find the thread that discusses camber and it's lack of effect on tire wear. Basically, if you get an alignment to correct toe, and your camber isn't way out of spec like with a moderate drop, you shouldn't really see camber wear. Especially if you rotate your tires properly.
knaira112387
Honda Civic (2006 - 2015)
11
May 1, 2009 08:07 PM
HondaCivic2006
Mar 19, 2009 04:40 AM
.water
Suspension & Brakes
11
Oct 23, 2005 08:24 AM
$amGD3
Suspension & Brakes
11
Sep 5, 2005 05:16 PM
Phat Corolla
Jan 10, 2002 10:27 PM
