weight reduction
Old Nov 19, 2008 | 04:15 PM
jyracer's Avatar
Default weight reduction
the lude is in the garage for the winter now and one thing im trying to do is take away some weight. i need some ideas besides the basic ones like interior. so give me some ideas
Old Nov 19, 2008 | 04:42 PM
OneRedLude's Avatar
Some of it depends on how comfortable you wanna be while driving lol.
You can start off with:
spare tire
jack
rear seats
trunk carpet lining
floor mats
cf hood (lose a good 14 lbs or so)
cf trunk
and then for the uncomfortable stuff...
ac
power steering
abs
passenger seat
misc carpet lining
there's more as I'm sure other H-T members will show you
Old Nov 19, 2008 | 04:52 PM
jyracer's Avatar
ive already got the comfortables done except the cf but i dont know how to take off abs. and is it possible to take off cruise control?
jyracer's Avatar
Old Nov 19, 2008 | 05:57 PM
117's Avatar
117
Cruise control is easy to remove, but why remove ABS? Eh, I still have ABS on my Prelude track car. Weight is 2,475 lbs without me in it, 1/4 tank of gas. It's a track car, though, so it's completely gutted, but has a full cage. This was with an OEM hood. It now has a gutted CF hood which saved a bit of weight. I need to do some work in the offseason to remove a few more lbs.
Old Nov 19, 2008 | 06:52 PM
twiztid00002's Avatar
i think this pretty much covers everything
https://honda-tech.com/forums/honda-prelude-4/%22how-can-i-make-my-prelude-lighter%22-thread-1036229/
Old Nov 19, 2008 | 07:15 PM
log1c's Avatar
man i still need to take off my cruise control, its just in the way right now hahaha
you could also get a smaller battery, and remove your windshield wiper reservoir
Old Nov 20, 2008 | 05:37 AM
Honda-R's Avatar
You wont lose that may pounds by taking of the cruise cntrl.
Old Nov 20, 2008 | 08:19 PM
streetracer6rpt's Avatar
car looks good... i still need to corner balance mine....
Old Nov 20, 2008 | 11:47 PM
Slow_BB6's Avatar
Im at 2683 with me in car and a 49/51 crossweight, abs, sunroof and heat remain!
eliminated-cruise, ps, evap purge, all interior panels accept front section, sound deadening, ac, heat shields, vis hood/deck lid, etc etc etc.
Old Nov 21, 2008 | 05:29 AM
117's Avatar
117
Thanks. Those weights aren't corner balanced. I just put the car on the scales to see what it weighed. It actually is setup a bit differently now. I have a CF/fiberglass hood (gutted), and I now run 17x8.5 RPF1s.
I need to get a litte more weight out of the car, though. I've thought about cutting out the door bars since I use NASCAR bars on the drivers side, lightening the bumper supports, and some other misc. things like that.
Old Nov 21, 2008 | 01:07 PM
i see now..... my door bars are gone, it was a PITA.....
Old Nov 21, 2008 | 02:32 PM
ketchup's Avatar
That's a nice set of scales, how much and where to?
Old Nov 21, 2008 | 07:24 PM
teefunk01's Avatar
If its a street car I wouldnt do much ... safety becomes an issue
But if its a track car some things could be
Bumper supports
heater core
interior pieces that arent being used
seats
sound deadoning
Old Nov 21, 2008 | 10:15 PM
kingh90's Avatar
get carbon fiber everything whlile you at it...Carbon fiber hood, carbon fiber lipkit, carbon fiber trunk, carbon fiber sway bars, anything carbon fiber does it.....;;;00000
Old Nov 22, 2008 | 08:15 AM
preluderemis's Avatar
lightweight rims also help imo...went from stock alloys to 12 lbs 3 pieces rims and noticed a difference...prolly just because the motor is turning less weight
Old Nov 22, 2008 | 09:00 AM
japan actually came out with full carbon fiber rims. they must be pretty light
Old Nov 22, 2008 | 05:42 PM
kingh90's Avatar
yeah they cost $ 10,000 for a set of 4
Old Nov 22, 2008 | 05:53 PM
117's Avatar
117
I would not remove the bumper supports. That's a really bad idea on a street car or track car. My bumper supports saved the front end of my car when I rear ended a fellow racer at TWS this past year. Without the bumper supports, my front end would have been toast.
Bumper supports
heater core
seats
sound deadoning
Old Nov 22, 2008 | 05:54 PM
117's Avatar
117
How did you do it? Do you know how much weight you saved? Also, did it make the doors floppy at all?
I certainly wouldn't do this in a street car, but I have NASCAR door bars on the driver's side and an X-brace on the passenger's side of the cage.
Old Nov 22, 2008 | 06:02 PM
117's Avatar
117
A friend of mine and I bought them together. We got a pretty good deal. IIRC, they were around $1k new, but we bought them second hand for under $600.
Old Nov 22, 2008 | 08:17 PM
brandobot89's Avatar
how do u remove the insulation on the stock hood safely? anyone have a write up? how much weight do ureally save?
Old Nov 23, 2008 | 03:46 PM
cutting torch or a plasma cutter will work... it was close to 50lbs of BS...its crazy how heavy they are. The doors dont flop around really.. not as strong as factory but still ok. you also haft to drill out a few things on the door.. it just takes time.
Old Nov 23, 2008 | 04:32 PM
117's Avatar
117
Cutting torch or plasma cutter? I was hoping to not have to repaint the door after removing the bars.
team123luder's Avatar
Can't you drill through your bumper brace? Since it's a track car?
Sound deadening material isn't much but dry ice and a hammer make it an easy choice, removing excess wiring also helps. heater core/blower and anything that isn't used.
Also adding a fuel cell and removing the spare trunk well helps.
