Overheating Problem on 91 si
Old Nov 10, 2008 | 05:44 AM
Smanos22's Avatar
Default Overheating Problem on 91 si
my 91 prelude si (b21a1) is still overheating and icant figure out the problem. i just replaced the timing belt and water pump and prior to this it wasnt over heating. car started to over heat when i got it back together and thats when i tried the water pump, but it still over heats. i noticed a small hole in the top of the radiator. looks like a plactic mount snapped off and where theres a peice of the plastic missing theres a pinhole in it. i noticed it when squeezing the hoses. could this be the problem of overheating? i also am having trouble bleeding the system. but what can i do/use to plug this small hole in the radiator? Should the hoses be full completly with coolant. it just feels like theres a little in there when squeezing them.
Old Nov 13, 2008 | 05:22 PM
fastaccord213's Avatar
Default Re: Overheating Problem on 91 si (Smanos22)
check if anything is leaking. thats the common cause for overheating.
Franky DB1
Jul 22, 2013 02:19 PM
EJ1_CRIS_909
Jul 18, 2012 10:03 PM
Null zahlen
19
Sep 14, 2009 02:10 PM
broke
Jun 10, 2002 01:49 PM
