Changing IM
Old Dec 26, 2008 | 12:20 PM
92SR4WS's Avatar
Default Changing IM
Hey everyone,
So this is my build that I am slowly piecing together:
-Portflow head package(Supertech Valves, Springs, Retainers)
-Skunk2 pro1 Cams
-Skunk2 pro Cam gears
-Euro R IM
-BDL 70mm TB
-ESP Header
-Custom 2.5" exaust
-stock JDM block(10.6CR)
Anyways I will be changing my mounts to Innovative or ESP ones soon and have to take my IM off. So I was thinking about putting the Euro R manifold and throttle body on while I have the OEM manifold off. I won't have the head built yet so I don't want to tune until I am completley done my build. I am curious whether or not puting the mainfold on before tuning will lose power or worse hurt my engine? Eventually I will do a full dyno tune but I would like to only have to pay once as I am poor!
Thanks for you help,
-Greg
Old Dec 26, 2008 | 01:41 PM
HdeucedeuceA's Avatar
Default Re: Changing IM
I have a Euro R and 68mm TB on my stock internal motor, untuned. I've had it on for like 3 months with no problems. There was even a noticable power increase from it and the TB.
Good luck on the build.
Old Dec 26, 2008 | 03:35 PM
gstrudler's Avatar
you shouldn't run into any major problems. changing the im is a pita. if you have the option, i would wait to get the head done and then do it all at once. be careful of the knock sensor when you're messing around with the im too.
Old Dec 26, 2008 | 09:08 PM
92SR4WS's Avatar
Sounds good. I plan on buying it a few months before getting the head done and I doubt I'll be able to look at it everyday and not put it on! Anyways thanks for the quick responses!
-Greg
Old Dec 26, 2008 | 10:22 PM
mattsnooz's Avatar
hey canuck, welcome to H-T!
Yeah, just wait and tune it when its all finished.
That im shouldn't do any harm without a tune. You might run a bit lean, but being your odb1 your ecu might compensate anyway would it not?
Baddawg1991
17
Nov 4, 2014 06:59 PM
92cxturbo
17
Oct 18, 2010 09:08 AM
NaCk3m
Nov 1, 2007 02:32 PM
PearlCrx
Dec 20, 2003 12:41 PM
No-Gi
Dec 15, 2002 08:05 AM
