ECU and electrical prob wont pass emissions!
Old 12-29-2008, 02:51 PM
kadidle's Avatar
Default ECU and electrical prob wont pass emissions!
i took my car to get tested today and it didnt pass because they couldnt make a connection with my ecu. I have a JDM type s ecu currently in my car. Do USDM scanners communicate with JDM ecu's ? Also they said my voltage was to low and that it could be a fuse. Would this low voltage cause my ecu not to communicate with the scanner? if not what would cause my ECU not to communicate with the OBD scanner?
Old 12-29-2008, 03:48 PM
duanes's Avatar
Default Re: ECU and electrical prob wont pass emissions!
What year/model/engine ?
Old 12-30-2008, 04:33 PM
kadidle's Avatar
1999 prelude but i did a JDM type s complete motor swap with ecu
Old 12-31-2008, 04:08 PM
kadidle's Avatar
bump
Old 01-01-2009, 11:33 AM
Lude Acts's Avatar
It should connect to the computer scanner. OBD II is OBD II. It doesn't matter what country it came form. The low voltage could be the problem. Check your grounds and power cables, and get battery and alternator tested.
Old 01-02-2009, 02:47 PM
kadidle's Avatar
so a low voltage i.e. bad ground or blow fuse or bad terminals could cause my ecu not to make a connection with a scanner
Old 01-02-2009, 05:25 PM
Crash_Control's Avatar
OBDII is a North American protocol. Europe has there own system and I do believe Asia has there own system also.
Old 01-02-2009, 09:05 PM
kadidle's Avatar
So OBD II JDM ECU's will not work with USDM OBDII scanners?
Old 01-02-2009, 09:42 PM
Lude Acts's Avatar
So why are there JDM ECU's that are OBD2????? you are wrong. OBD systems are universal
To the OP: did you check your grounds and fuses yet? Try going to AutoZone and have them hook up their code reader to it. See if it will work or not.
Old 01-02-2009, 11:08 PM
prelude_93vtec's Avatar
Ya check all fuses and grounds and what-not and get it tested at autozone for free.
Thank god for OBD1
Old 01-03-2009, 10:35 AM
kadidle's Avatar
going today
Old 01-03-2009, 04:41 PM
kadidle's Avatar
Its still not reading i need to figure out weather or not its the JDM ecu that just cant be read by a USDM scanner ?
Old 01-04-2009, 11:41 AM
Lude Acts's Avatar
Ooooops My bad. The more I thought about it, I think the Type S ECUs are OBD1. Which means that they may not let you pass emissions if you live in a tough state. You have an OBD1 engine in a car that is supposed to be OBD2. They kinda frown upon that sort of thing. You should be able to hook up and OBD1 scanner to the car to get it tested (not sure if the plugs are the same or not from OBD1 to OBD2) but the thing is the emissions people are going to give you a rough time because OBD1 in America is on 1996 and older vehicles. The emissions standards for cars '97 and newer (OBD2) are a little more strict. You might possibly be up **** Creek. What state do you live in? You could tell them that the engine is from a 1996 Prelude VTEC, and that the original engine died and was replaced, but they may not go for it. Good luck.
Old 01-04-2009, 05:30 PM
kadidle's Avatar
can anyone else verify that a type s is OBD I ?
Old 01-05-2009, 03:45 PM
kadidle's Avatar
So i was thinking about changing ECU's and putting my stock SH ECU in. I was thinking if its the ecu then the stock ECU will be able to be read. But i dont know know if it will hurt my type S motor and if my car will pass because it might run like ****. Suggestions ? anyone know if a type s motor is OBD I or OBD II?
Old 01-06-2009, 01:54 PM
kadidle's Avatar
anyone ?
Old 01-06-2009, 02:08 PM
A Blue Lude's Avatar
If I was in your situation I'd use the stock ECU.
Old 01-06-2009, 02:45 PM
97ludedude's Avatar
i would try the stock ecu also. worst case try to find an emmisions tech that takes bribes.
Old 01-08-2009, 09:51 AM
kadidle's Avatar
Is my stock USDM ECU going to hurt my type S engine? The type s is higher compression and higher lift cams and most likely has different timing and fuel map.
Old 01-10-2009, 07:30 AM
kadidle's Avatar
anyone?
hoursinexile
11-17-2009 10:14 AM
kadidle
Engine Management and Tuning
01-03-2009 07:32 AM
Mutsnuts
03-29-2007 09:56 AM
ctr status
09-14-2006 05:10 PM
Spy1r
03-03-2004 08:30 PM
Quick Reply: ECU and electrical prob wont pass emissions!
