H22A Engine Harness
Old Dec 27, 2008 | 03:44 PM
FunnyVictor86's Avatar
Default H22A Engine Harness
is h22A engine harness the same as usdm h22 engine harness? i cant find a h22A engine harness anywhere, thanks
Old Dec 27, 2008 | 04:48 PM
snobordboy's Avatar
Moderator
Default Re: H22A Engine Harness
They will do the same thing, and the jdm harness wil not have the plugs for the front water temp sensor, and possibly the vtec oil pressure sensor, since many jdm cars didn't have those.
Old Dec 27, 2008 | 10:12 PM
the thing is that i have a 01 accord ... i bought a h22A from a 98 ... i want to get a obd1 h22 wire harness for it ... so if i get a usdm harness im going to have extra plugs? that would that throw a check eng. light right? im confused lol
Old Dec 28, 2008 | 12:32 PM
anyone else have any ideas ... my plans are to run a obdI p28 ecu with a s300 hondata ... i want to use a plug and play engine harness for the H22A ... what harness can i use?
Old Dec 28, 2008 | 01:21 PM
Rob_O's Avatar
Modify the accord harness to work with the motor and use an obd2/obd1 adapter harness at the ecu
Old Dec 28, 2008 | 01:58 PM
92civlude's Avatar
Yeah. Rob is right! With the H22 on the out of the car, fit the Accord harness to the H22. You might have to make minor mods,One at a time! Like lengthen the alt wire or add knock sensor or whatever else. Then use a OBD1 to OBD2 conversion adapter harness on the OBD1 ECU. Ive seen so many guys start cutting up harnesses and eventually getting lost.
Old Dec 28, 2008 | 04:15 PM
i think im going to have to end up doing that ... i was just trying to save my harness in case i ever have to convert back to the F series motor ... thanks guys
UniqueX707
Nov 24, 2014 11:33 AM
mike541
Apr 13, 2011 01:40 PM
RACEPAK
Jan 28, 2011 03:31 AM
tunerraceteam
Feb 22, 2009 03:49 PM
3.point.2
Aug 11, 2004 06:05 PM
