In need of some info on my harness
Old 01-06-2009, 05:20 PM
Default In need of some info on my harness
Hopefully within the next month I plan on swapping my H23 with a H22a from hmotors. Now I'm all set on swapping motors, but I'm not that good when it comes to wiring up VTEC. The h22 came with a jdm ecu and harness, but I'm going to use a OEM ecu.
Will I run into any problems if I use the jdm harness with an oem ecu?
If I use an oem harness will I just be able to hook everything up with out having to worry about seperetely wiring the VTEC.
Also if there is any other issues I'll probably run into, please warn me.
Thanks.
#1 luder is offline
Old 01-06-2009, 05:27 PM
Default Re: In need of some info on my harness
I would use your stock harness thats in the car the ECU you recieve with the swap and buy this http://rywire.com/store/9295-prelude...b4516f0370a1c3 and it will solve all your problems
boostin99ek9 is offline
Old 01-06-2009, 05:35 PM
OK, so with that I can still use my H23 harness and that rywire hooks straight to the h22 ecu?
#1 luder is offline
Old 01-06-2009, 06:05 PM
Correct!
Old 01-06-2009, 06:13 PM
Alright thanks. For some reason when it comes to the harness my mind goes blank.
#1 luder is offline
Accordian47
04-25-2016 04:27 PM
eg_h22
01-18-2008 02:42 PM
Saosinx
07-07-2006 11:07 AM
TypeRKoncepts
03-31-2004 09:37 PM
humtake
05-08-2003 06:01 PM
Quick Reply: In need of some info on my harness
  • Ask a Question
Question Title:
Description:
