ABS help fast!!!!
Old Dec 28, 2008 | 10:55 AM
Lude-venom's Avatar
Default ABS help fast!!!!
short story: 92 lude wth abs light on after driving for ten or so min. stays on. checked the code and comes up LR wheel sensor. Pull the wheel off and pull the orange plug to it and get no reading(0 hms) for both the orange clip holes and to a steel ground. What do I need or need to do.
Old Dec 28, 2008 | 11:10 AM
Paul-R's Avatar
Default Re: ABS help fast!!!!
there i a open in the wire you need to follow it to see where it's at might be a short .
Old Dec 28, 2008 | 11:12 AM
Lude-venom's Avatar
from the female end of the orange clip to the actual sensor?
Old Dec 28, 2008 | 11:17 AM
Lude-venom's Avatar
bump pls help meeeeeee
Old Dec 28, 2008 | 01:12 PM
Lude-venom's Avatar
ok took out the sensor and checked it looked fine so i put it back in. then i checked the codes again and it flashes 4 then a paus then another 8. i think that it is the LR sensor can some one confirm that please so im not ****in around when i dont have to be.
Hondaman56
Sep 21, 2012 07:44 PM
ludee00
Nov 21, 2005 04:22 AM
kmcmpb11
Oct 12, 2004 08:47 AM
FK00GSR
Apr 25, 2004 04:09 PM
Dirt
May 22, 2002 12:38 PM
