speedo
Old Jan 5, 2009 | 06:05 PM
atownludeh22a's Avatar
Default speedo
I cant get my speedometer to work, I have changed my vss and i have changed my cluster, and traced back all my wires, I'm at a loss I dont know where else to look. any thoughts
Old Jan 6, 2009 | 11:38 AM
92civlude's Avatar
Default Re: speedo
What year is your car?
Old Jan 8, 2009 | 12:27 PM
Default Re: speedo
1992 Prelude SI 4WS
Old Jan 8, 2009 | 01:34 PM
92civlude's Avatar
Default Re: speedo
check for power at fuse 23, at the srs fuse block. its on top of the underdash fuse box. use a test light. next at the vss connector. unplug it, looking at the wire side of the connector ( the back side) 1st wire should be black-continuity to ground the middle wire-black/yellow should have 12v with the ignition switch on 3rd wire orange should have contiuity to speedo connectors orange wire. hope I was able to help!
Old Jan 8, 2009 | 04:42 PM
BlackCatt's Avatar
Icon6 Re: speedo
If you replaced your vss with a new one, then sorry i cant think what it could be, besides a wiring issue. If you got a replacement vss unit from a wrecker you may have had extremely bad luck as i did 3mths ago. I replaced my vss with a used vss and it would work for 5 mins every time the car was started from cold and then stop working. I got an auto elec. to have a look and he said it was definately the replacement vss, and to get a refund and buy a new one, as they arent too much more price wise. So i got a new one and no prob since. Good luck with it. I know its a f%&king pain not having the speedo up and running.
Old Jan 11, 2009 | 01:32 PM
Default Re: speedo
i replaced it with a new vss and vtec is working so i dont think its an issue there, i put a gage pod from an automatic in the car which is a 5 speed could that be the issue
matchewspoo
May 2, 2010 01:47 PM
H22a1civic
Dec 19, 2006 09:41 AM
H22a1civic
Dec 19, 2006 07:29 AM
chewabacha
Feb 22, 2005 09:57 AM
SIMATIC
Jul 30, 2003 01:19 PM
