Need help!!
Old Jan 8, 2009 | 12:41 PM
Redprelude98's Avatar
Default Need help!!
So i know it has been asked probably more times than i can count, but i was wondering what is it that i will need in order to go from my 98 prelude obd2 to a jdm h22a obd1? what all will i need to do in order to make this work?
Old Jan 8, 2009 | 04:57 PM
boostin99ek9's Avatar
Default Re: Need help!!
Peter from Rywire.com told me a obd2a-obd1 conversion harness and a obd1 ecu he said your obd2a distributor will still work
Old Jan 8, 2009 | 08:05 PM
so in other words i will just need a conversion harness for the ecu and use the obd1 ecu and then also use my obd2 distributor? because i have heard that i will need to change my injectors and use some other parts off of my obd2 motor?
Old Jan 9, 2009 | 11:46 AM
I would say use your same injectors that are currently in it because OBD1 injectors use whats called a resister box i'm unsure on how to wire it up or if its needed for that matter but your Intake mani. that came with the car should suffice
Max500
Aug 5, 2010 05:26 PM
civic-one
Jul 30, 2009 06:00 AM
stevil_knevil
Nov 10, 2006 07:06 PM
C_I_V_I_C
Nov 5, 2003 05:26 PM
inline4
15
Sep 9, 2003 03:03 PM
