distributor help??
Old Feb 28, 2009 | 07:53 PM
313hitman's Avatar
Default distributor help??
I have an internal mounted coil in my dizzy but all the auto parts stores around here say that my h22a1 should have an external mounted dizzy. how do I get the cap and rotor I need?
Old Feb 28, 2009 | 08:05 PM
Giant_Bean's Avatar
Default Re: distributor help??
rotor is the same, ask for a cap from a 00 civic si, that will work with the internal coil distributor.
Old Feb 28, 2009 | 08:43 PM
313hitman's Avatar
thanks I really appreciate it.
Old Feb 28, 2009 | 09:04 PM
313hitman's Avatar
should I switch to the stock external or would it fine as is??
Old Mar 1, 2009 | 05:13 AM
Acidcrakker's Avatar
If you switch to a stock external distributor set up, your going to need an external coil as well, not to mention the distributor.
Pros and Cons
Pros
External coil is further away from heat source that can cause failure
They are easier to get warrientied and replaced in america
Cons
Its about 400 bucks for a brand new set up
Old Mar 1, 2009 | 06:57 AM
lrayford's Avatar
but what about aftermarket, dosent msd only work with external?, i think mines internal?
i say this b.c the coil seems to be under the cap and thats how it was in my gf's integra so no msd for me :[
Old Mar 1, 2009 | 07:28 AM
autoluder's Avatar
you will probably never make enough horsepower or RPMs to need MSD.
Old Mar 1, 2009 | 07:43 AM
lrayford's Avatar
yeah b.c you know all about the fully built h22 im having built and turboed sitting right next to my prelude right?
loser.
Old Mar 1, 2009 | 08:07 AM
You might need a MSD, but the OP and 95 percent of the whole entire fourm doesnt.
I personally wont buy a MSD unless my OEm fails
Old Mar 1, 2009 | 04:37 PM
autoluder's Avatar
loser.
wasnt talking about you...
But stock ignition systems are very good, most people who buy msd have no real use for it.
xlusiveracer
Feb 3, 2018 07:03 PM
JRF
Jan 24, 2013 08:17 AM
joncowden
Mar 11, 2008 06:14 AM
BreakMaster
Sep 9, 2004 11:49 PM
dyg2001
Feb 24, 2004 09:38 AM
