Engine grind
Old Feb 20, 2009 | 10:40 PM
paniaguae640's Avatar
Default Engine grind
I have a 94 honda prelude si H23A1 2.3l... at idle i dont have a grinding noise coming from my car, but when you accelerate there is this grinding noise coming from the engine and as the RPMS get higher the grinding gets louder and when i decelerate the grinding goes away. What could it be?
Old Feb 20, 2009 | 10:45 PM
LuckyXIII's Avatar
Default Re: Engine grind
Are you sure it's not the bearings in your hubs? Just a thought...know that makes a grinding sound, just not from the engine.
Acidcrakker's Avatar
Check your crank pulley bolt. I know it may sound wierd, but I remember that I had a strange grinding sound coming from one of my motors before, and I couldnt figure out what it was. A week or so later the crank pulley bolt shot off, and destroied the crank.
Old Feb 20, 2009 | 10:48 PM
wheres the crank pulley bolt located?
Old Feb 20, 2009 | 10:51 PM
heres more of a description.... the engine gets louder but not as loud as it used too and the grinding growls at you
Old Feb 20, 2009 | 11:29 PM
Kronn 98SH's Avatar
Do you get the grinding if you rev in neutral?
Old Feb 21, 2009 | 12:09 PM
no not while reving in neutral... could it be a cracked exhaust manifold?
Old Feb 21, 2009 | 12:14 PM
The problem showed up after redlining my car.
Old Feb 21, 2009 | 12:18 PM
Kronn 98SH's Avatar
Unlikely since your car still produces exhaust while in neutral. It sounds more like a moving part OUTSIDE of the engine. Maybe tranny, flywheel, clutch, etc.
Old Feb 21, 2009 | 09:04 PM
i just found a loose screw on the cover of the exhaust manifold.... i don't know if that's it.
Old Feb 21, 2009 | 09:38 PM
92bb2's Avatar
its the standard control unit located next to the secondary control unit on the left side of the engine bay. Go to an auto parts store and get a new one. They're cheap: $4 and it'll fix your problem.
Old Feb 22, 2009 | 09:34 AM
when i press in the clutch and shift the noise goes away. but once i let out the clutch and accelerate the noise comes back
Old Feb 22, 2009 | 07:24 PM
Yes it makes the noise when in neutral and i rev.
Old Feb 22, 2009 | 07:58 PM
h23prelude's Avatar
--this makes me believe its a transmission related noise, but a pry bar to the transmission ans the handle part to your ear (this works just like a stethoscope) and have a friend produce the noise as you pin-point the source of the noise.
check ur transmission fluid and tell us what it looks like, or if its low
Old Feb 23, 2009 | 07:23 PM
found out that if i rev in neutral to 2500 rpms the noise is there ticking. But it seems to be coming from the direction of the headers.
Old Feb 24, 2009 | 05:00 AM
mattsnooz's Avatar
Record an audio or we aren't going to be able to play "name that sound". We hear what sound your hearing we might be able to help you out.
Old Feb 28, 2009 | 02:44 PM
duanes's Avatar
Only an opinion -
If it started this after a redline, there is a strong chance the it is bearing issue.
1. If the crank bends it will cause a binding on the main bearing.
2. Any of the tranny bearings prior to the clutch.
3. I believe that the flywheel has balance weights - maybe one was thrown off.
4. Maybe spun a journal bearing in the engine.
bigboi407
Apr 18, 2016 04:18 PM
PR8urVtec
Aug 24, 2010 11:24 AM
starsky22
Feb 26, 2008 12:26 AM
Elevorett
Jul 21, 2007 09:32 AM
fatalman
Nov 13, 2005 06:43 PM
