F22B DOHC Valve Clearance
Old 07-25-2009, 08:41 AM
PTVDesign's Avatar
Default F22B DOHC Valve Clearance
pls help me
i can't find specification for ENGINE F22B DOHC...
i need know realy Valve Clearance of F22B DOHC - it's JDM engine for HONDA Prelude
i know about similiar H23A1 and F22B DOHC, but need find original specifications...
Old 07-25-2009, 10:26 AM
PirateMcFred's Avatar
Default Re: F22B DOHC Valve Clearance
It's the same as the H23A1
Old 07-25-2009, 05:43 PM
PTVDesign's Avatar
i set exhaust valve clearance to 0.15mm and It is not enough
Old 07-26-2009, 10:12 AM
The OEM exhaust clearance specification is .15mm to .19mm. I don't know what you're doing to determine that .15mm is not enough but if you think it's not enough then add some more clearance.
Old 07-26-2009, 04:37 PM
PTVDesign's Avatar
now set is 0.17 and engine work roughess, every 40 second is break...
vacuum in IM increase on IDLE
Old 07-27-2009, 03:50 AM
That sounds like you're running big cams, or possibly have the cam timing off? Good luck.
Old 07-27-2009, 04:24 AM
PTVDesign's Avatar
it's engine from Japan, maybe he is was modified, timing is good.
where ex.. valve clearance was 0.23-0.25 the engine work perfect, but where we adjust to 0.17... problems is began
Old 07-27-2009, 04:34 AM
0.23-0.25 sounds pretty loose. Get a degree wheel and a dial indicator and see what you get for duration and valve lift at zero valve lash. Stock cams are around 180˚ duration at 1mm lift and overall lift is ~9.5mm.
Otherwise look at cam timing and make sure it's timed correctly. Make sure the ignition timing is correct and maybe reset the ECU to delete anything bad it has learned.
Old 07-27-2009, 04:41 AM
PTVDesign's Avatar
thanks, we try test it
Old 01-13-2013, 11:43 PM
w002mia's Avatar
I know this is an old thread but i need to know the specs too.
VALVE LASH FOR INTAKE AND EXHAUST for V4 ACCORD DOHC
laloquera916
Honda Civic (2001 - 2005)
05-09-2016 09:30 PM
mhewitt
09-16-2010 10:51 AM
eintsius
12-20-2008 01:03 AM
getgot22
12
03-06-2007 06:36 PM
Quick Reply: F22B DOHC Valve Clearance
