running rich and need help
Old Jul 31, 2009 | 11:29 PM
h22 kid's Avatar
Default running rich and need help
ok well here is the issue... a friend of mine has an h22a4 and is running a p06 converted to a p28 vtec with a basemap tuned to that ecu... ecu is running on crome as of now. its an ob2 engine and the injectors size, i believe are 290cc; well one of his injectors just blew and now his motor is running on only 3 cylinders. could it be that the basemap was tuned for a high flow amount of air to run in causing the injectors to work over its 80% potential and thus blowing it out? any help here guys... no CEL's were thrown, at least not that i know of. oh yeah and his motor is idling pretty ackward.... so please any insight or feedback on this will help out
Old Aug 1, 2009 | 02:23 PM
h22 kid's Avatar
Default Re: running rich and need help
bump
Old Aug 2, 2009 | 01:18 AM
1BADEGDC2's Avatar
crome ... lol ... but maybe its just a bad injector? if another one goes then somethins defenitly up, could also be wiring ...
Old Aug 2, 2009 | 09:40 AM
TheCivicMafia's Avatar
Crome isnt bad, you just got to know what your doing.
Could of just been the injector, Also your tuner could not know wtf he is doing.
As for basemap, Idk did it always run bad or when did it start?
Old Aug 2, 2009 | 02:37 PM
h22 kid's Avatar
well it hasnt been tuned for the h22a4 but it was tuned for the jdm h22a. so he figured it might have worked easily im guessing. i thought so too that it could be a bad injector.
Old Aug 2, 2009 | 03:04 PM
AznBlueBoy's Avatar
the jdm h22 and h22a4 have different injectors. a jdm h22 map uses more gas because of the higher compression on it.
Old Aug 2, 2009 | 03:42 PM
h22 kid's Avatar
i know that thats why i said could it be that the h22 map caused more air to be pulled in causing the injectors to work overload thus blowing it??
Old Aug 2, 2009 | 03:54 PM
1BADEGDC2's Avatar
not makin fun of crome ... makin fun of cHrome ... lol and yea thats correct, the injectors are shootin at different rates, get the injectors that were tuned for the ecu, or retune ...
Old Aug 2, 2009 | 03:58 PM
h22 kid's Avatar
oh **** lol my bad!!! i'll fix it
Old Aug 2, 2009 | 04:05 PM
You swapped motors and didnt retune? Well then, theres your problem. Azn Is pretty close to being right
Heres the USDM and JDM Compression ratio, Compare and decide.
Compression ratio:
10.0–10.6:1 (North America) This being H22a4
10.6–11.0:1 (Japan) This Being h22a JDM
Old Aug 2, 2009 | 04:15 PM
h22 kid's Avatar
Compression ratio:
no motor was swapped it was just the ecu's
Old Aug 2, 2009 | 04:26 PM
Same concept.
Old Aug 2, 2009 | 04:40 PM
h22 kid's Avatar
ha ha ok well thanks bro
ludesleep
Oct 8, 2007 04:00 AM
99gsr-t
Oct 13, 2005 03:10 PM
Scean
Feb 23, 2005 05:39 PM
teg92
Jun 2, 2003 11:35 AM
