92 prelude help. (shifting) auto.
hey i have a question? my prelude is having problems shifting from park to drive or park to reverse but from drive to park its perfect??? do u know what the problem is??
tranny fluid? i hurd its suppose to be pink or sumtin?
or my friend said it might be my tranny itself? bcus my rpm kicks high?
any ideas?
and my car is an automatic
any ideas?
Re: 92 prelude help. (shifting) auto.
Well first thing to do is a transmission fluid change. Buy some ATF - Automatic Transmission Fluid ( comes in quarts ) directly from Honda and do this in your driveway. I don't have my Helms manual in front of me, but I will make sure to look up how many quarts of ATF to buy for a full flush + refill and the like, will update soon.
Do you park the car on a hill? The reason i ask this is that with automatics, sometimes the car will roll a bit after your park and it'll put tension on your transmission making it harder to shift out of park the next time you start your car.
Try this: when you go to park your car... with it still in gear (drive or reverse), hold your foot on the brake pedal and then pull your e-brake BEFORE shifting it into park. See if that helps the next time you go to start your car.
If that doesn't help, then go with the fluid change street_ride suggested. If all that doesn't fix your problems, then it might be time for a new tranny.
fanoftheb00st
12-30-2008 02:31 AM
unorthodox
11-25-2006 08:28 PM
