driver side headlight has no power
I'm in need of some help. My driverside headlight will not power on, 94 prelude. Neither high beam or low beam. Passenger light works fine. I swapped the head light relay, changed head light fuses, no go. Blinkers and parking lights work fine. ive checked the ground near the headlight and it appears OK. I also tried grounding the low beam head light to the chasis and still nothing so im assuming i've got no power. I pulled the dash and have been checking for any damaged wires. It appears the previous owner had an alarm - there are some cut wires for the door locks under the steering column but the connector they are cut from isnt plugged into anything ( thinking its for factory alarm). There is also another connecter that is not plugged in, but i think that is the fog light relay connector(brown plug), shouldnt matter cause i dont have the fog lights. Everything else looks good. I have spent days trying to figure this out. Can anyone give me some advice what i should check.
Re: driver side headlight has no power
Initially I was thinking it's either a relay or fuse problem, but you say you checked and replaced them. If bulbs are in working condition, then it has to be a wiring issue which I think you are aware of. Recheck grounding points, maybe a cut wire shorting out ? .. Did you always have this problem or is this fairly recent. ?
sik_sol
03-31-2005 04:15 PM
